CZ TX waveform:
IMO, the CZ is a primitive MF design in that a basic square wave drives the coil and the RX uses the 3rd harmonic to notch out salt water. Other than that, the harmonic really isn't used so the CZ otherwise behaves like a 5kHz single frequency detector. Both Minelab BBS and White's DFX were big steps forward in that they boosted the high frequency and then used both frequencies for target & ground analysis, not just salt notching. Newer MF designs do even more analysis, often with 3 frequencies.
BTW, CZ tech isn't dead, Minelab used it in the X-Terra Pro. The XT-pro is called a SF detector but it can notch salt, in exactly the same way as the CZ.
