I just made this (AI made it, is is just my novice attempt):
what is it really AI ?
https://chat.deepseek.com
Metal Detectors: Principles and Applications Overview
Metal detectors are electronic devices designed to detect the presence of metal objects, often buried underground or hidden within other materials. They are widely used in security screening, archaeology, treasure hunting, construction, and military applications (e.g., mine detection). Here’s an overview of their working principles and types:
1. Basic Principles of Operation
Metal detectors work based on electromagnetic induction and disturbances in electromagnetic fields caused by metallic objects.
Key Components:- Control Unit – Contains circuitry, controls, and processing electronics.
- Search Coil (Antenna) – Transmits and receives electromagnetic signals.
- Shaft & Handle – For user handling.
- Display/Audio Output – Indicates detection (beeps, visual signals).
2. Physics Behind Metal Detection
Electromagnetic Induction (EMI)- Transmit Coil (TX):
- An alternating current (AC) passes through the transmit coil, creating a time-varying magnetic field around it.
- Eddy Currents in Metal:
- When this magnetic field encounters a conductive metal object, it induces eddy currents in the metal (Faraday’s Law of Induction).
- Secondary Magnetic Field:
- The eddy currents generate their own opposing magnetic field (Lenz’s Law), which distorts the original field.
- Receive Coil (RX):
- The detector’s receive coil picks up this altered field, and the control unit processes the signal to indicate metal presence.
- Used in high-end detectors (e.g., for deep detection or mineralized soils).
- Instead of continuous AC, it sends short, powerful pulses of current.
- The decay time of the induced pulse is measured; metals affect this decay rate.
3. Types of Metal Detectors
A. Very Low Frequency (VLF) Detectors- Most common type (affordable & versatile).
- Uses two coils:
- Transmit Coil (TX): Sends a low-frequency EM field (3–30 kHz).
- Receive Coil (RX): Detects the disturbed field from metal.
- Can discriminate between metals by analyzing phase shifts (different metals affect the signal differently).
- Better for highly conductive metals (gold, silver) and mineralized/wet soils.
- No discrimination capability (detects all metals).
- Used in underwater detection and military demining.
- Simple and cheap (rare in modern detectors).
- Two oscillators: one in the coil, one in the control box.
- Metal changes the frequency, producing an audible beat.
4. Discrimination & Target Identification- Ferrous vs. Non-Ferrous:
- Ferrous metals (iron, steel) are magnetic and easily detected.
- Non-ferrous metals (copper, gold, aluminum) require higher sensitivity.
- Phase Shift Analysis (VLF):
- Different metals alter the signal’s phase shift, allowing discrimination (e.g., ignoring nails but detecting coins).
- Conductivity & Frequency:
- Higher frequencies (10–30 kHz) detect small gold better.
- Lower frequencies (3–5 kHz) detect large, deep objects.
5. Factors Affecting Detection- Soil Mineralization:
- Highly mineralized soils (e.g., saltwater beaches) can cause false signals (PI detectors handle this better).
- Metal Size & Depth:
- Larger objects are detectable at greater depths.
- Orientation of Metal:
- Flat objects (coins) are easier to detect than narrow ones (nails).
- Interference:
- Power lines, other detectors, or electronic devices can cause noise.
6. Applications- Security Screening (airports, buildings).
- Treasure Hunting & Archaeology (coins, relics).
- Industrial Use (food processing, construction to detect rebar).
- Military & Humanitarian (landmine detection).
- Underwater Search (shipwrecks, lost jewelry).
7. Advanced Features in Modern Detectors- Ground Balance: Adjusts for soil mineralization.
- Multi-Frequency Detection: Simultaneously uses multiple frequencies for better accuracy.
- Wireless Connectivity: Bluetooth for headphones/data logging.
- GPS & Mapping: Tracks search patterns and findings.
8. Limitations- Cannot detect non-metallic objects (plastic, ceramics).
- Depth limitations (usually a few feet, depending on soil and object size).
- False positives from mineralized rocks or electromagnetic interference.
[QUOTE=ivconic;n438963]I just made this (AI made it, is is just my novice attempt):
:clapand you could have put a caption on the bottles like from the 22nd second of the song... - https://www.youtube.com/watch?v=SmUj...&start_radio=1
You never know when a brilliant idea will strike you!Originally posted by Carl-NC View Post
He should be holding stone tablets.
I'm a prophet, I know for sure that new ideas for a book will appear... when you least expect it!
BTW... AI gave me an idea today... which may not be new, I need confirmation on this!
In endless "conversations" with the AI, we accidentally came up with an interesting idea, which may not be original.
The classic PI RX frontend includes a stronger resistor for current regulation with two inverse "clamp" diodes.
And this is where the biggest problem occurs, the biggest signal loss, that is, the biggest influx of noise.
The AI calculated that more than 90% of that "signal" was actually noise.
Is the original (or not) solution to throw it all out and put in an ultrafast mosfet that will disconnect the coil from the RX frontend when the TX pulse is in progress?
The mosfet will change state only when the pulse is turned off and the decay starts.
I am writing this here because I will forget later.
- Likes 1
I think the AI misunderstands what’s happening. Or I misunderstand.
The TX pulse, the way I see it isn’t a source of noise, but it must be dissipated before the voltage is low enough for op amps. The pulse shouldn’t be introducing much spurious signals, but a predictable rise and fall without much random harmonic content
Not the TX pulse per se, but the series resistance and clamping diodes.Originally posted by van0014 View PostI think the AI misunderstands what’s happening. Or I misunderstand.
It's hard for me to judge AI otherwise.
Sometimes it says something very interesting, on the border of genius, and sometimes it disappoints and I wonder what it is all about!?
In any case, I have a positive attitude towards AI.
(Whoever lives with cats - quickly becomes very tolerant)
:rotfl
As you increase the resistor value to improve protection, you unintentionally form an RC filter with the op-amp’s input capacitance (and PCB parasitics), which reduces signal bandwidth.
For PI detectors sampling short pulses (10–80 µs), this matters, especially for small/fast-decaying gold signals.
At high temperature, the clamping diodes (especially if not Schottky) can leak microamps and introduce noise near the threshold region.
This leakage adds to input offset current or creates asymmetry in response.
If supply rails are not symmetric, or if one diode begins conducting before the other (due to manufacturing variation), you can get non-linear or distorted clamping, which causes signal asymmetry or odd behavior on return swing.
When a weak signal (or environmental noise) approaches the diode conduction threshold (~0.6V for silicon, ~0.2V for Schottky), the diode begins conducting non-linearly, which acts like a poor logarithmic amplifier — distorting the signal and amplifying noise differentially.
The resistor+diodes configuration can cause ringing at the op-amp input if there's any parasitic inductance (from the coil, long wires, or PCB layout). This can produce false peaks or chatter in the signal.
The resistor itself introduces noise in the signal path. This is called Johnson-Nyquist noise, or more commonly thermal noise, and it's an unavoidable physical property of all resistors.
There’s a few times i’ve used AI, and it’s a convenient way to search for things. It does get it wrong, but also helps sometimes
Whoever has cats.. there are 6 of them at my house, and I think 9 is the most we’ve had, so I guess it applies to me!
Being based on existing human knowledge, I found AI’s limits in anything innovative that hasn’t been tried before or documented.
When I present it with my theories or ideas, it doesn’t really try to explore them enough. Just acknowledges that they could work
There’s a currently growing problem of AI content online being in a sort of feedback loop with AI training source material, where it’s degrading it’s performance by ingesting it’s own content, which is scattered across the net.
Though I use it, i’m slightly negative towards it. And am aware that it degrades our brain’s neurological pathways for learning, as we use it we depend less on our own problem solving skills and keep turning to it to give us an answer that otherwise would have taken a bit of research and effort
It certainly helps sometimes, with all the car diagnosing questions I ask it. It’s like how search engines should have been, where they seem to know what you’re asking for
AI is a terrible weapon, more terrible than a thermonuclear bomb - it will vaporize you in milliseconds and you will not feel anything. However, AI "fried" people's brains through smartphones. The research of psychologists is desperate!!! Children live in virtual reality, they are functionally illiterate, they cannot think. They rarely talk, looking into each other's eyes (as if they are autistic), they rarely enjoy the beauty of birds and nature, staring at the smartphone screen ... ... spiritual decline and total dullness accelerates over time. AI has been talked about intensively for about 3 years, but its early versions have been used for at least 15 years... AI is used in large chain stores for greater profits and sales through price variations and other dirty sales tricks. A huge amount of information is processed, weekly statistics on sales of goods, video information from cameras... and more things can be said, but I don't want to depress you...The level of homo sapiens is shown in this super short film -https://www.youtube.com/watch?v=0Kfn4faB2gI
There is essentially nothing you wrote that I disagree with.Originally posted by van0014 View PostThere’s a few times i’ve used AI, and it’s a convenient way to search for things. It does get it wrong, but also helps sometimes
"...Being based on existing human knowledge, I found AI’s limits in anything innovative that hasn’t been tried before or documented..."
Yes, that is my basic "complaint". In one of the previous posts I wrote that I am not sure if I am happy about it or not.
In case of "bad intentions"; it's better if the AI doesn't have the ability to think outside the box. But where is the progress?
The ability for AI to think outside the box would be a real revolution and greatly accelerated progress. Human life could be raised to a new, unimagined level.
But the fear of that is also justified. History teaches us that any good thing can easily turn into a bad thing.
