I have changed slightly the LC-tank circuit. And put a DPDT power toggle switch simulation via jumper.
There is only one big tune capacitor Ct (instead of two bigger). FKP1 foil capacitor with low losses if possible.
The small capacitors Cs2 and Cs3 are now doing the voltage division (capacitive voltage divider).
Keep Cs2 as low as much. Change Cs3 if required.
Cs1 is a compromise between power and high-Q. Make Cs1 bigger and you get more power to the TX coil but the Q will go down.
Below is a zipped LTSpice simulation file for your convenience. It simulates a time-domain circuit behaviour for -0.5%, 0% and +0.5% change of TX-coil inductance approx. 200 Hz above the resonant frequency. If you make an AC analysis, Q can be calculated in the graphs. Q = I(Ltx) / I(Cs1), this is now the correct calculation.
That's a long way to get there.
