Originally posted by Qiaozhi
yes it does montecarlo analysis ... next time I'll use it before making mods or circuits to be sure or changes involved. Thanks.
About coil... yes... to be homemade with strange things it looks not too bad.
But what I like more is weight : 350gr total is very relaxing for arm... without wasting performances.
I've used the surfboard approach... polystyrene bubbles to keep weight low and epoxy to reinforce it and polypropilene bottom... and it works pretty cool.
The little work was on cutting polystyrene foils and I've made and hot cutter using NiChrome-wire and a PWMedd Mosfet... like in model airplanes starters... and it cut that like a laser
Best regards,
Max
I found it worked good... just some chatter sound from time to time... nothing else. I think that's impossible to damage TGS even at 100% humidity cause it doesn't use lot of power or hi-voltage... so it's safe as using an MP3 player in your kitchen... it can work there for years without problems ! That's what I think.
