I sent the processor for my XP Gmaxx2 to China, but they couldn't deliver it, and they refunded the money.I paid a ridiculously small amount, and they refunded the money.Do you think anyone could accomplish this?
Hacked XP ORX firmware
Isn't it cheaper to contact the XP company directly and buy the detector from them?
XP Gmaxx2 is a very good detector.
But nowadays you can design something similar yourself with the help of AI.
It is not a problem to understand how the detector works, nor is it a problem to design such a detector.
The problem is in realization and materialization.
Everything has become more expensive and now it is no longer worthwhile to make detectors, it is much cheaper to buy them.
I used to try r3 and r6
Had the same issue in 2nd factory program.
The gadget sounds are fully off and on while switch settings: reactivity, thrashhold or small iron filter.
What's interesting my previously saved program based on gold was Ok.
Maybe it was based on the 1st program.
Ivconic
When you have a spare moment, could you upload a photo of the radio TX area of the GMP board?
There is this recent thread:
Help for XP ADX 150 - Unknown 10-pin IC near crystal (TX stage) - Geotech Forums
Though the original poster no longer wants help, it would be useful for everyone else if there was a picture of the RF IC added to the thread.
Thanks.
(Click to enlarge)
These are the images I already had on the disc.
If you want additional pictures; say. I will open my GMP and take a picture.
But it was totally destroyed, I don't remember if the part of the pcb you are interested in remained whole or it was also destroyed to such an extent that the photos won't tell you much.
I have no problem opening it and taking pictures, if these pictures don't help you.
Ah, I found random pictures of my GMP, not ideal but maybe they can help.
If you still want close-up details of a specific part of the pcb; say and I'll take a picture.
The mess you see in the pictures is the result of the "repair" of some "top expert" before me.
I bought this detector from the owner and keep it for "decoration"...
I've never used headphones with any detector (dated back a long time ago, from an ear injury) and so I don't know if XP GMP is constantly "broadcasting" via TX or
if there is some process even when wireless headphones are not used; then TX is off.
If TX is on all the time; then what comes out of the TX can be analyzed.
There are several ways.
The first step is SDR dongle and SDR sharp with FFT.
If the range is in 433-460MHz and the signal is raw audio; i have a couple of Baofeng duo and tribanders, they cover all those bands,
i can check what's going on very easily (provided my GMP works in that part... alas... PIC is burnt, probably not working, i can only catch the carrier).
The next step up for the more advanced is Flipper Zero with the appropriate plugin.
And as for the BT range; Wireshark and a lot of "workarounds" around it... with some of the better nRF52840 modules.
If you want a pro level; HackRF One, of course!
Thanks for responding, the area of the board that's needed is the TX circuitry: two Xtals ( TX1,TX2), two frequency-multiplying digital FM oscillator IC's, and a few R's+C's:
We know what it does, it's just the exact IC they used that's not known, there are a few similar possibilities, Melexis, Silicon Labs, etc. As your 'library' photos show, there is no marking on them... perhaps your own GMP has the IC's with the part numbers marked.?
[ It generates 32x the quartz xtal freq, in the 433MHz ISM band. Modulation is digital FM, it's assumed the GMP generates PWM audio, both to the headphones and the RF TX.]
Toggling between the two TX freqs is achieved by selectively enabling / disabling the IC needed, so it is likely that when headphones are used, both TX IC's are disabled. I'm not so sure about the RF add-on PCB that fits older GoldMaxx, GMaxx1, Adventis etc, that may be transmitting full-time.
Also. You may not realise, but original complete GMP's have a (weak ) screen/shield over the receive front-end circuitry, where your damaged area is. It was originally carbon-loaded plastic, heat-staked to the PCB, they later added some tinned copper wire melted into the plastic, to make it a bit better.
So far I have "serviced" (trivial things) over 30 XP GMPs and I certainly know about the existence of that "plastic".Originally posted by Skippy View Post...Also. You may not realise, but original complete GMP's have a (weak ) screen/shield over the receive front-end circuitry, where your damaged area is. It was originally carbon-loaded plastic, heat-staked to the PCB, they later added some tinned copper wire melted into the plastic, to make it a bit better.
My poor GMP doesn't have it, I'm 100% sure that the previous "serviceman" cleverly concluded that it was of no use and threw it in the bin!
Melexis TH72015 ?
7201
5.2
1103
It is clear that they "rebranded" some components in XP.
First, two xtals.
Only the measurement on the correct device will reveal the frequency of the crystal and thus help in the further "decryption" of the chips.
Although there is a good chance that they are Melexis TH72015.
Basically, that's the part of GMP that interests me the least! Ha, ha, ha!
I am most interested in 3, 5 and 6 pin SMD components.
I guess the previous "seriviser" burned most of those chips.
But then I remember that the PIC also burned and that kills my motivation to investigate further...
Hello, everyone. My name is Dan. I realize that I'm getting a bit over my head here, but I've been working with ChatGPT and, to a lesser extent, Claude AI in an attempt to see if it is possible to write a utility to back up, restore and share custom programs from the Deus II.
We've made some progress analyzing the JavaScript behind XP's web-based firmware updater and identifying much of its USB communication protocol. We've also examined the Deus II firmware binary that Marchel posted, which appears to be encrypted.
My goal isn't to modify the operating firmware itself, but rather to find a way to access the user-program data.
I think some of the work you have all been doing here parallels what I've been doing, although apparently with a different goal. I just thought it might be worth asking if anybody here has made similar attempts or has any information that might be helpful to my project.
