Hacked XP ORX firmware
    That's why I switched completely to the ESP32 family in the last couple of years.
    It is impossible to hack them (except maybe the Chinese, who make it, probably left some back door).
    But nothing can stop the Chinese anyway.
    The idea of ​​intellectual property protection, at least in my case, is to protect my work first of all from petty beggars and local "witch doctors" who ruined the business with metal detectors in the local markets.
    There has been such a large influx of "experts" and "experts"; that today it is very difficult to sell an honest DIY detector.
    That's why I'm totally out of that story.
    It no longer puts bread on the table.
      Here is the offline updater for the XP Deus 1 one could glean a lot of information from it, but I haven't had the time to look into it in more detail.
      Secure, fast and free cloud storage solution. Upload and share files instantly.
        You know, that all metal detector hackers will get into the iron stone field hell with flat batteries.
          In the meantime, I did a little research.
          I have to admit that I've been pretty "rusty" since 2013 when it comes to "hacking" Deus.
          Things are not simple, the ".bin" files I sent are not valid and it is my fault.
          I had to start "Process Monitor" and do the update to V5.21 again on my Deus 1, in order to catch the temporary files that the updater puts on the disk for a very short time and then deletes them.
          Ha, ha, ha!
          Very cunning!
          But not so hard in the end!
          Here are finally the real .bin files for V5.2 (deus-update-en-521_138.zip):
            https://gofile.io/d/HaVAB3r7
            While I worked from the previous post; you have already uploaded an offline package in which all those files are already exposed... even easier!
              Took a look at the .txt files from the DEUS UPDATE package (remote, headphones, coils...).
              They’re not plain Intel HEX. Each line is 64 bytes of hex text with its own header (type/address/length), no checksum.
              The interesting part: addresses inside the file don’t run in order.
              They jump by a fixed step (always +716eight, then after 9 jumps drop sharply back near zero, with a slower secondary trend that shifts every 7-8 cycles.
              That pattern points to interleaved writes across multiple flash banks rather than a straight linear memory dump.
              Because of that, the data can’t be disassembled as PIC24 code until the exact address sequence is solved, and I couldn’t fully crack.
              Whether this is deliberate obfuscation or just how their flash-write routine happens to work, I honestly can’t say for sure; the pattern alone doesn’t prove intent either way.
              Still, one has to admit that the guys at XP did a good job.
              Dubious analysis and work of several days would still give results.
              But as I said a couple of times; it doesn't put bread on my table.
              So I'll end this nonsense here.
              This was an interesting little thread for the forum, to break up the monotony.
              And now; back to the real world, off to do something useful!
                Do Something Useful ... I was always a bit surprised that no-one here had tried 'cloning' the popular and effective GoldmaxxPower ( GMP ), known here in the UK as the "Hammy Hoover" [= hammered coin vacuum cleaner].
                The hardware in the detector is quite modest, and should be easy to reverse-engineer. The PIC is quite low-end, with only a limited amount of code.
                The problem is: to make the clone legal, you would need to replicate the functioning of the original code, without actually using any of it. Disassemble it, understand it's functions, write new source-code. A lot of effort, skill and perseverance would be needed, plus the cost of getting the original code extracted.
                The possibility of adding featured is tempting ... 5 or 4 tones could be interesting.
                  I agree with you that the Gold Max Power is an exceptional detector, even, I would venture to say that it is better than the Deus in some respects.
                  I have an XP Gold Max Power, totally broken, mutilated by some fool who thought he knew something and tried to "service" it.
                  The coil remained intact, but the PIC was damaged, as well as several components on the pcb, as well as several copper connections.
                  How did I establish this?
                  Friend has 100% correct Gold Max Power and at the risk of taking damage; I moved the PIC to his machine and sure enough, it didn't work.
                  After switching on, the usual "chime" is heard and stops there, there is no reaction anymore. Burnt PIC.
                  Bootloader and kernel are still working but peripherals are burnt (read as: burnt IO pins).
                  And then I put my coil on his detector (put it back to the original working PIC) and everything worked correctly.
                  Conclusion; coil correct, PIC burnt.
                  Apart from the PIC being burnt, as I said, there are a lot of signs of incompetence and a lot of damage to the pcb, as well as broken connections.
                  That's what you get when a jerk tries to play "master repairman".
                  So I have a pcb that I can now completely "clean" of components without worry.
                  But there are broken traces, vias, etc, so I'm sure in advance I won't know which goes where.
                  Well, it makes the whole business pointless.
                  However, there is something that is an even stronger argument that refuses me to "trace" the pcb.
                  And it's a bunch of some very small SMD components that either have no markings or have some markings that don't say anything.
                  I had a new Gold Max Power in the period 2010-2012 and then I sold it and bought a Deus 1.
                  I have experience in operation.
                  Back then I was researching whether it was possible to reverse engineer the PIC.
                  I can tell you that we mere "mortals" cannot do that.
                  This can only be done by specialized laboratories that dissect the chip, look at what's inside with a microscope and manage to read the contents in a very complicated way.
                  I think we have mentioned this many times on the forum over the past 20 years.
                  The fact that it is a very old PIC model, very rudimentary, can be said to be "ridiculous" by today's terms; does not mean that it has weak protection, on the contrary!
                  And finally, one more thing. I wrote this a couple of times somewhere on the forum, in the last 10-15 years. I think someone already did this (paying "$XX K" to a specialized lab) long before us.
                  My first encounter with the Nokta Velox One... a few hours of work with that detector; I got the overwhelming impression that I was holding Gold Max Power in my hands.
                  I have no evidence, I have nothing, just a feeling. I have worked with Gold Max Power for a long time and I know how to recognize the behavior and specific features of the detector.
                    Isn't life funny and full of paradoxes?
                    The Loubett brothers, as hobbyists, loved to search with Fisher 1265 detectors.
                    Then, as amateurs in their garage, they started the production of a digital clone... precisely the 1265 model!
                    Ha, ha, ha!
                    The complete 1265, otherwise Dave Johnson's intellectual property, they just moved (partially) into the digital domain (baseband sampling) and made "their" first detector, which first became a big hit in France.
                    After selling a lot of units and making a big pile of money; the brothers embark on much bigger ambitions. The rest is history.
                    Then there's my fairly accurate suspicion that they've cloned Gold Max Power into Nokta...
                    By the way, before the appearance of the Velox One model, Nokta was very notorious as a totally bad and charlatan company that produces garbage.
                    It is also about brothers. lol
                    The smarter brother founded the company Makro, in order to distance himself from the bad image of the name "Nokta", and later the integration took place.
                    Because people are like chickens, they have a short memory!
                    And we "old school" experts are dying slowly, disappearing, there is no one to convey the truth to new generations.
                    This forum remains as a testimony from the past, it carries a lot of history and true facts.
                    But here we are witnessing frequent hacker attacks on the forum.
                    I wonder who is funding it?
                    This is not about hacker enthusiasm.
                    In my past life I also worked as a professional hacker for a while.
                    I know for sure that without a bunch of money, nothing will happen by itself.
                    Geotech forum bothers someone.
                    And that someone has a lot of money and finances hacker attacks on this forum.
                    I'm not going to spread various conspiracy theories.
                    But I clearly see the matrix in the behavior, I've been following it for years.
                    The main goal is to kill the truth, revise the past and create a new reality.
                    That's the bottom line.
                    It is all the more important that this forum is maintained and preserved.
                    A complete backup should be made on one of the archive servers.
                    I even suggest more than one.
                      Quote: "plus the cost of getting the original code extracted"
                      Paying for (probably Chinese experts) to extract the code is what I was meaning, but I don't believe it's as expensive as it once was.
                      I forgot to mention the possible GMP clone(s) ... Keith Southern, a frequent poster on Dankowski's forum, said ( if I recall correctly ) he felt the Deeptech Vista X had a lot of GMP in it.
                      Another potential problem with making a GMP clone is the coils. I believe they are not the simplest , and there are no aftermarket 'copies'. So a clone control-box would probably have to be paired up with a genuine XP coil ... and they are expensive.
                      Maybe this rolling tone-ID all-metal mode is not that hard to replicate, without resorting to reverse-engineering XP's code?
                      Unmarked SMD parts is a common issue nowadays, you just have to remove them and measure them, then use your skills and judgement to deduce what they are.
                        I will definitely agree with you about the most important thing; the coil.
                        Another deterrent.
                        25 years ago I would have been very motivated and enthusiastic, today... oh no!
                        The detector is, as I wrote, baseband sampling, nothing special these days.
                        With paid Claude and a little basic knowledge; anyone can write code for such a detector.
                        The problem lies in the second; high-quality low-noise material, pcb design... and of course the coil!
                        We have reached an era and a state when many things have been completely thought out, which until only 10-15 years ago had both meaning and a great future.
                        Today this is no longer the case, today such known technology is easily replicated with the help of AI.
                        It is not even necessary to clone an existing device.
                        What is still interesting today is a good idea, something new, something that no one has done in that way before.
                        The hardest task!
                          Do you think that’s realistic ?
                          https://vk.ru/wall-174695418_84194
                          It works fine
                            Yes, I found this video, and it’s actually real it works.
                              great
                                would it be possible to connect an original XP Deus 2 coil with a custom homemade control unit box? Im in doubt if all the processing of the XP Deus 2 is done inside the coil or in the control box.
