Tesoro Mayan VLF/TR
    ...inca redrawn and routed ( could be errors ... but for 10 minutes work thats the risk ).
      Arrrrghhhhhhhhhhhh!
        Hi Paul,
        Not sure ... It seems to have a good idea about working out how a circuit works and it does know things about common faults in old electronics like electrolytics and dirt etc.
        However it could not analyse my mono coil circuit correctly ... it didnt seem to know that simultaneous rx and tx was possible in PI detector but once I told it how it worked ... it went "aha" and now it knows.
        yep, AI is not good at circuit analysis & design yet. I had the same experience.
        And it is still making big mistakes in complex coil analysis tasks.
        And I should never start an AI chat with my smartphone. I could not save the whole interesting AI conversation about my coil analysis.
        Anyway, I have made dozens of screen shots of the AI chat results. But the big portion of the AI chat is lost.
        Aziz
          The circuit board looks authentic—just like circuit boards from the '70s and '80s...
            Arrrrghhhhhhhhhhhh!
            Circuit Slop. Coming to AliExpress soon.
ID:	454750 Here are the pictures that I just took of the Mayan. Click image for larger version  Name:	top1.jpg Views:	0 Size:	663.6 KB ID:	454743 Click image for larger version  Name:	bottom1.jpg Views:	0 Size:	737.7 KB ID:	454744 Click image for larger version  Name:	top2.jpg Views:	0 Size:	659.9 KB ID:	454745 Click image for larger version  Name:	top3.jpg Views:	0 Size:	670.5 KB ID:	454746 Click image for larger version  Name:	top4.jpg Views:	0 Size:	651.5 KB ID:	454747 Click image for larger version  Name:	top5.jpg Views:	0 Size:	647.5 KB ID:	454748 Click image for larger version  Name:	top6.jpg Views:	0 Size:	575.1 KB ID:	454749
                  That's what I call good enough photos to work with!
                  While I was redrawing the pcb; I noticed a lot of things known and already seen on other Tesoro detectors.
                  There are some values ​​that I could not interpret.
                  In general; my eyesight is poor, these values ​​I entered should also be checked.
                  ​Click image for larger version  Name:	PCB.jpg Views:	0 Size:	734.6 KB ID:	454762Click image for larger version
                  Sprint Layou5 (or 6) pcb file, subject to complete, correct etc.
                    The CA301A (LM301) can be replaced today with a much more modern opamp with a much better S/N.
                    As well as opamps in chain.
                    The transistors in the metal case are probably fet, you just need to confirm which ones they are.
                    Although, for that role, many can be used.
                    When you correct and complete my pcb redraw, you add all the values and info; I will trace the schematic from the final pcb file.
                    On original device I would also replace all capacitors with newer, better quality ones, preferably WIMA.
                    Tantalum also needs to be changed, it's too old, same goes for elcos.
                    The zener diodes are also clearly visible on the pcb, but I didn't want to guess, it's better to confirm it.
                      I will look at the other needed parts numbers on the board and post them.
                      Ivconic, thank you for all your effort..............
