Tesoro Mayan VLF/TR
  • Tesoro Mayan VLF/TR
    Just bought a minty looking Mayan. Tuning drifts a little in VLF Normal mode and the meter doesn't work. Otherwise works like it should.
    Wondering if any one has schematics for this detector?
    No schematics, but there's a user manual here -> https://www.manualslib.com/manual/22...?page=1#manual
      Hello cousin!
      Instead of spilling various manuals from your sleeve here; you better finally fix smileys!
      I have no material to work with here!
      Bruv!
      Mate!
Name:	Rolling With Laughter Emoji.jpg
        thinking if Tesoro made just one schematic for all models (mean analog) so this is just variation. pics of board needed for identification.
        I can give GMT King Cobra sch again... but i did that million times.
          When I open up the detector again will take pictures
            The Aztec might be close to the Mayan? It's from about the same time period around 1982. If similar, your drift problem will be around the CA3130 op-amp
            Click image for larger version  Name:	Tesoro Aztec.jpg Views:	0 Size:	325.0 KB ID:	454668
              [QUOTE=ivconic;n454649]...you better finally fix smileys!..
              yup, i am missing some smileys too.
                [QUOTE=ivconic;n454649]Hello cousin!
                Bruv!
                Mate!
                I haven't forgotten.
                    I happened to read somewhere that Mayan is a nugget hunter?
                    Or am I wrong?
                    It's hard to find data.
                      I wanted to see how my KICAD AI bridge build is working .... so I pasted the board image into the prompt and this is what KICAD spat out ( 10 minutes to redraw the schematic and layout the board ).
                      What is important is the AI did not use an autorouter .... its laid out by "eye" and "signal".
                      This is the first complex board it has ever drawn ... and it learns. Time to cancel my Altium sub LOL.
                      Click image for larger version  Name:	image.png Views:	0 Size:	137.8 KB ID:	454680​
                      Click image for larger version  Name:	image.png Views:	0 Size:	627.4 KB ID:	454679
                      ​Click image for larger version
                        That's crazy.. The advice for fixing the drift is dead on. The other parts seemed solid too.. In many cases the actual problem is oxidation on the pcb that causing leakage and then the drift. So how did AI know this? Did it find a old forum post somewhere that mentioned these things, or did it develop the ideas on it's own?
                        It would be interesting to see if it could do a schematic of a 2 layer pcb with just images of the top and bottom.
                          from Melbeta's files.
                          82y manufactured begin. something between Aztec Cortes Amigo and Inca Silver Sabre.
                          Tesoro:
                          1980: Deep Search VI, Deep Search IV, Deep Search VII
                          1981: Aztec, Cortes, Amigo
                          1982: Scout, Mayan
                          1983: Inca, Silver Sabre
                          1984: Sabre II, Sabre Supreme, Silver Turtle
                          1985: Golden Sabre, Cutlass
                          1986: Silver Sabre Plus, Eldorado, Royal Sabre
                          1987: Toltec 100
                          1988: Toltec 80, Diablo, 4 Reale, 8 Reale
                          1989: Golden Sabre Plus, Lobo
                          1990: Bandido, Pantera
                          1991: Diablo II, Silver Sabre II, Stingray, Laser B1
                          1992: Cutlass II, Golden Sabre II, Laser B2
                          1993: Bandido II
                          1994: Toltec II, Sidewinder
                          1995: Piranha, Stingray II, Laser B3
                          1996: uMax Bandido, uMax Cutlass, uMax Diablo, uMax Sidewinder, Amigo II
                          1997: Shadow X2, Lobo SuperTRAQ, Laser PowerMax, Bandido II uMax, Silver Sabre uMax
                          1998: Cutlass II uMax
                          1999: Sand Shark, Laser Rapier
                          2000: Conquistador, Compadre, Golden uMax, Tiger Shark
                          2001: Cortes, Conquistador uMax, Eldorado, Euro Sabre, Silver uMax
                          2003: DeLeon, Tejon
                          2004: Cibola, Vaquero
                            Not sure ... It seems to have a good idea about working out how a circuit works and it does know things about common faults in old electronics like electrolytics and dirt etc.
                            However it could not analyse my mono coil circuit correctly ... it didnt seem to know that simultaneous rx and tx was possible in PI detector but once I told it how it worked ... it went "aha" and now it knows.
                            I have a chinese clone board that is surface mount that I will see where it gets with reverse engineering.
                              Just took the Mayan case apart and removed the circuit board. Doing a parts comparison between the Mayan and Aztec, they are not the same. Found a schematic for the Tesoro Inca in my files. Again comparing
                              the Mayan circuit board to the Inca schematics parts. Looks to be a match. Click image for larger version
