Tesoro Mayan VLF/TR
  • #31
    [QUOTE=ivconic;n454796]I am just retracing the schematic looking at the pcb.
    Typical Tesoro frontends.
    But I noticed something, these two resistors can't be 5k1 by no case, the smallest value can be 100k but also higher, need to check!
    Took a look at them again, they are 100K
    • #32
      Never mind, I still see "5k1" on your post...
      You can replace them with 220k and larger, if you want to experiment with higher amplification though.
      I will finish schematic and post it here for eventual corrections...
      • #33
        Switched out the image with the corrected one in my previous post, so not to confuse.
        • #34
          • #35
            This need to be checked...
            • #36
              schematic Click image for larger version  Name:	sch.jpg Views:	0 Size:	440.9 KB ID:	454839
              • #37
                Correcting some parts.
                This was added
                Cap 15 10% Click image for larger version
                • #38
                  The Mayan is now stable.
                  Replaced:
                  Electro caps
                  Box caps
                  Tant cap
                  IC's --CD4024, LM358, LM393, CD4016
                  Have on order LM301 and CD4053
                  When turned on:
                  The meter still jumps from zero to 9 for a couple seconds then to full and will not drop down. Since the meter wire goes to CD4053 pin 14, thinking the leaking battery dripping damaged this chip?
                  When my order comes in I will replace it.
                  • #39
                    I tried to trace the schematic from the pcb drawing as accurately as possible.
                    I probably made a mistake somewhere, it happens.
                    Everything is clear except for the connection around the switch as well as one "strange" wire that goes from pin 9 of the CD4053 somewhere...
                    I can't see exactly where that wirre goes in the pictures.
                    On my schematic, the only thing left to do is to draw which wire goes where and how it goes to the switch.
                    Mayan is definitely not the same as Inca.
                    Although I am quite an "expert" on Teosoro detectors; Mayan seems quite unusual and interesting to me.
                    In case we arrive at a 100% accurate schematic; maybe this winter i will draw my pcb and make a diy.
                    I have a pair of stock coils for Tesoro older series, it would mean to me that the specs of the Mayan coil are measured exactly.
                    The fact that I have coils; is the only reason for my motivation to make a Mayan diy,
                    as well as the fact that I like the schematic and that it is a bit unusual.
                    ​Click image for larger version  Name:	Tesoro Mayan.jpg Views:	0 Size:	378.6 KB ID:	455072
                    • #40
                      I'm sure that the performance of the Mayan detector can be significantly improved with some modifications.
                      But it should come to that.
                      The first step is to establish a 100% accurate schematic.
                      P.S.
                      Also I need values for all potentiometers.
                      • #41
                        I will check the switch wires and post a picture.
                        Pots
                        Disc. Level B10K
                        Sensitivity B10K
                        Ground Balance B10K
                        Threshold with on/off switch B10K
                        • #42
                          • #43
                            anyway, you can ask them to share pics of board INCA Tesoro Inca coil question | Friendly Metal Detecting Forum
                            and we will compare.​
                            • #44
                              Here are the power pictures. Any other pictures you require let me know. Very easy for me to take the pictures and post them.
Name:	on off switch.jpg
ID:	455091 Click image for larger version
                              • #45
                                Thanks!
                                Though; On/Off switch and battery cons are trivial and easy to dig out.
                                Most important for me is this part:
