Tesoro Mayan VLF/TR
  • #46
    Use hand draw on paper or MS Paint and draw simple wiring as they are on switches.
    Also this one, the "WIRE ?" on my schematic, goes exactly where?? (marked with red circles on photo)
    • #47
      Mayan is definitely not the same as Inca.
      anyway, you can ask them to share pics of board INCA Tesoro Inca coil question | Friendly Metal Detecting Forum
      and we will compare.​
      Mayan and Inca are definitely not the same.
      If you look at the schematics; clear differences are immediately noticeable.
      However, there are also similarities.
      I wouldn't want to guess, but it seems to me that the Inca is a "modernized" version of the Mayan model.
      Irrelevant.
      In this case we will focus on Mayan and "decipher" it to the end.
      Also, the boxes are similar.
      It is possible that Mayan came out first and then Inca as a slightly more advanced version... I'm just guessing.
      • #48
ID:	455102 Click image for larger version
ID:	455103 Click image for larger version
ID:	455104 Click image for larger version
        • #49
          More pictures of the circuit boat trying to make the resistors more identifiable.
ID:	455108 Click image for larger version
ID:	455109 Click image for larger version
ID:	455114 Click image for larger version
ID:	455110 Click image for larger version
ID:	455111 Click image for larger version
ID:	455112 Click image for larger version
          • #50
            Click image for larger version  Name:	image.png Views:	0 Size:	219.2 KB ID:	455121
            Splendid!
            But you didn't provide this information:
            • #51
              Splendid!
              Will put that up a bit later on
              • #52
                • #53
                  I skimmed through Paul's schematic and found errors in my schematic!
                  Here is the more accurate version for now.
                  And I wonder; why would pin 9 of the CD4053 go to the coil connector???!
                  Is there any logical explanation?
                  Here are corrections and update:
Name:	Mayan Pcb IC2.jpg
                  • #54
                    Selector switch
ID:	455131 Click image for larger version
ID:	455132 Click image for larger version
ID:	455133 Click image for larger version
ID:	455134 Click image for larger version
                    • #55
                      • #56
                        Browsing through the backup disks...
                        Click image for larger version  Name:	image.png Views:	0 Size:	1,012.0 KB ID:	455140
                        Click image for larger version  Name:	image.png Views:	0 Size:	997.1 KB ID:	455141
                        I don't know if you noticed this detail in the advertisement!!!
                        Ha, ha, ha!
                        The perfect way to turn all the flaws into virtues!
                        Click image for larger version  Name:	image.png Views:	0 Size:	27.6 KB ID:	455152​
                        • #57
                          ​Click image for larger version
                          • #58
                            Mayan manual:
                            • #59
                              Looks like my guess was right.
                              The Inca is the successor of the Mayan.
                              Judging by the price difference; Inca is a somewhat improved detector on the Mayan platform.
                              I'm not too smart, but as soon as I saw those antediluvian fet transistors; (at the time when Jesus was doing electronics...) - I immediately assumed that it was some heavy "antique"...
                              CLICK TO ENLARGE
                              Click image for larger version  Name:	Isus.jpg Views:	0 Size:	644.1 KB ID:	455148​
                              Searching for the mark on the schematic, it would not be possible to find the datasheet.
                              But with a little help of intuition I found the datasheet.
                              And that only confirmed my suspicions and assumptions.
                              Ok... enough History, back to work now!
                              The datasheet:
                              • #60
                                There is only one more unknown for me, intrigue, I will quote myself: "And I wonder; why would pin 9 of the CD4053 go to the coil connector???!"
