50 ma make more sense
I was googling dsp metal detector algorithms to see if I
could find something some university or whatever might
have done with public money, get some of it done for free.
Or some good ideas, of which there have been many over
the years. Some of the walkthroughs use DSP more for
real, but then they are plugged into the wall for power,
and not much space constraint. Still is a challenge.
Poor DTex. The DSP Monster probably ate em up.
Took a bit bite out of some others.
Should of used Wavelets, I told them they should of
used Wavelets.
An embedded computer using sophisticated software provides high speed Digital Signal Processing (DSP) and self-monitoring diagnostic programs which ensure consistent, highly stable drift free operation.
The ability to reject interference (electromagnetic noise) from outside sources, separates the quality detector from others. This type of interference, caused by equipment such as fluorescent light ballistics, computer monitors and photocopiers cause inferior units to regularly false alarm. Some manufacturers mask noise rejection problems by using IR sensors' that deactivate their units until a person walks through. These IR devices, sometimes referred to as traffic counters, can actually allow weapons or contraband to be passed, slid or tossed through the detector without it alarming! Avoid dangerous security breaches by selecting a detector that is continuously active
The 18 ZONE uses highly efficient electromagnetic interference rejection algorithms and unique circuitry to eradicate the high false alarm rates common to many detectors. The unit thrives in environments where other detectors are rendered inoperative.
http://www.feelsafer.com/18zone.html
Originally posted by Carl-NC
used Wavelets.
. Serial out, 10-pin pkg.
