Originally posted by Tinkerer
I don't have a PI-IB rigged up right now, so someone else will have to verify.
Originally posted by nick_f
I use a 1"x1" aluminum (sorry, aluminium) foil square as a standard test target. On V3 it has a VDI number of 4 and hits hardest at 22.5kHz. Now sandwich 2 of those squares together and I get a VDI of 8. I have these sandwich stacks (laminated in clear packing tape) with thicknesses of 1, 2, 4, 8, 16, 24, and 32x. All still 1"x1" mind you. When I get to a 32x thickness the VDI is 60. When I stack the 16x, 24x, and 32x together (total of 72x) I get a VDI of 78 (US dime) and it hits hardest on 2.5kHz.
You can do the inverse with silver... foil-thin silver will read like a low-conductive target and respond better to high frequencies.
As any VLF coin hunter knows, trash responds literally all over the scale. So does jewelry. Gold nuggets do, too. So, skin effect probably plays a greater role in target response than does the metal alloy itself. We tend to calibrate on standard targets (coins) that are consistent (and consistently thick), so we deceive ourselves on the importance of "conductivity". It is really admittance, where skin effect plays a prominent role.
- Carl
