Hah!
Finally i got one original Tesoro, just for me!!!
It is Bandido II (not uMax).
It is very cute small machine. Extra lightweight! Two 9V batteries connected in parallel - providing more current and last longer.
Coil 20cm.
Extra good discrimination! Almost the same as on my TGSL's.
Frequency exact 10.02 kHz!
Excellent All Metal mode - static, nonmotion. Excellent! Autotune also works excellent. Manuall GEB works good, but not rejected 10cm ferrite rod totally. It reject it very good, yet very short cracks appears when rod is about 5cm away from coil surface...hmmm..this could lead me to learn to adjust GEB on my TGSL's a bit "softer" in future. Clay,hotrocks and blacksand rejected 100%.
Very good behavior overall.
Yet.....
air depths are not so great! Same old, famous 1e coin, at same setup on the plastic bench (setup i always use to test all detectors) it is detecting bairly at 23cm in air. Just to remind; TGSL, with 27cm DD coil, same coin, easilly "eating" at 32 to 34cm!
I tried to keep all adjustments the very same on Bandido II as on my present TGSL. And i just did testings on both at the same time. Very simillar except air depths on 1e coin. So...this Bandido will need new coil very soon!
Next week or two i intend to perform some more detailed checks, measurements and analyze...
Enjoy!
Coil 20cm.
Yet.....
air depths are not so great! Same old, famous 1e coin, at same setup on the plastic bench (setup i always use to test all detectors) it is detecting bairly at 23cm in air. Just to remind; TGSL, with 27cm DD coil, same coin, easilly "eating" at 32 to 34cm!I tried to keep all adjustments the very same on Bandido II as on my present TGSL. And i just did testings on both at the same time. Very simillar except air depths on 1e coin. So...this Bandido will need new coil very soon!
Enjoy!
