Finally the real "high-efficiency" treasure-hunting can start:
Now with the 3rd wheel its possible to drag the coil the broad side over the ground.
The idea how to attach the 3rd wheel was simple and perfect - using just some very hard wooden board for the wheel-fork
and improve the strenght there, but usual it's only around 4-12 kilogram weight force - so no big deal.
Depending if the 3rd wheel is attached below or over the coil (both is easy possible), the coils ground-distance is ca. 5cm to 15cm.
This is perfect, depending how flat etc. the surface is. And as it has been tested already, its no problem to search at
sensitivity 80-90 if this huge coil is almost directly over the floor. If it would be higher just a loss of depth would be the result.
At very stony etc. regions or inside some kind of jungle still the possibility with 2 holding belts exists - the usual 2 persons solution.
But sometimes its better to do such work on your own, not all the time somebody else has time etc.
Of course to dig really deep and large holes someone to help would be great, and with this coil I will go for the real deep and huge stuff.
In our modern days of china-plastics such a "scooter" could be produced very simple and cheap and perhaps Makro Group will see
the fantastic possibilities such a device offers and includes it to his profi-package which also includes the 1m coil.
If the non-metallic pole and the coil-cable is long enough or extensionable, such a "highspeed-searchcoil" also could be attached behind a car or bike.
That way flat huge regions are open to real treasure-hunting and discovering new promising hunting sites will come in easy reach.
With this construction now per instance even deep sunken larger war-remainings can be found just by driving around fields, plains or whatever.
This coil is sufficent to find already 3-5cm (1-2'') small stuff near the surface but the real power starts with around 10cm finds and below 50cm depth.
Of course everything with discrimination and also cavity can be found.
Not to forget: treasure-hunting this way is much more relaxing! Its like a walk in the park and dragging some lightweight cart behind.
Even some drink-bottles and food in plastic-boxes can be put on top of the coil so the backpack or whatever remains lightweight -
at least in the beginning.
And what I sometimes like the most is..... discrimination by size! That way someone can fully concetrate on the "huge finds".
Many of them still are crap but its still much faster to find the real precious big stuff and those finds which are not reachable
by the usual sized metal-detectors (with coils up to 45cm) at all.
Too bad at the moment its deepest winter here but I'll present you the first test-results in spring.
Good luck and let's hope that this new great "hunting-method" incl. whats needed will be available soon for everybody.
, I can't carry around, they must change their coils.
