ARADO 120 SCH& PCB
  • #61
    Originally posted by Pete61 View Post
    This quote from Andreas #30
    you must build a electronic-cap
    Originally posted by nimalgr View Post
    HAS ANYBODY A SCHEMATIC FOR ELECTRONIC-CAP PLS?
    What is it?
    • #62
      Originally posted by daluka View Post
      What is it?
      Like this
      but controlled by DC voltage, not your fingers.
      https://www.usefulcomponents.com/mai...iable_cap.html
      • #63
        Like this
        Variable Capacitor
        • #64
          Originally posted by ANDREAS View Post
          Hi all
          All you have heard for "Myth " arado120.
          I make this two years ago, with fine results and new design PCB . This machine has voice for all metals and Ameter for discrimination. With this method, we can heard a detection target and with eyes, we can see dicrimination
          Here is sch diagram without errors and full analytical PCB (101,60mm X 81,28mm) without errors too. The next post i publish infos for (how make Tx-Rx coil). My machine work with O-O coils 20cm diametre and detect a euro 36cm distance on air, a box 20cm X 20CM 95cm distance on air . Maybe with D-D coil is better... we want try for this. In practice never i use, only inside laboratory. Easy make PCB, with easy coils and difficult calibration "null".
          I don't answer questions, why I believe this is very analytical, only you want make PCB.. put parts and finish
          In next post I will present photo's, Method of calculations coilsand method calibration "null"
          I wish good success
          best regards
          Andreas
          Can you post the files in "Express pcb" format. In PDF format I can't edit the board trace​.
          • #65
            Andreas has not been here for a long time.
            • #66
              Apparently I'll have to redraw the board myself​.
              • #67
                Good morning colleagues, yesterday I received an original Arado 120B, after maintenance, I have brought it back to life, everything works, it came with an original coil, the only thing is what depth should I put?
                It has an 8" coil and accepts a 1 euro coin at approximately 25 cm.
                I would like to know if making a coil could increase or improve the performance. I have heard that it was very deep, but it doesn't seem that way to me, I don't know if it should be tuned, part of the board comes with Epoxy so you can't see the components.​
                I also wanted to ask if it is possible to set a Ground Balance.
                • #68
                  Just in case if someone is interested....
                  I see a Classic Arado 120B with meter discriminating metal detector currently offered on eBay UK.
                  Here is the link https://www.ebay.co.uk/itm/126670959733?
                  • #69
                    Patent 4096432, Arado Electronics, Paul Anthony Spencer
                    • #70
                      daluka
                      Geotech Metal Detectors - Patents (geotech1.com)​
                      • #71
                        In 1987 when I was 21, I went to London and bought my first detector.
                        That was the Arado 120 you are talking about here.
                        I used it until 1991/2 when I sold it and bought a White's Eagle IIc.
                        Ah... the good old days! Brings back so many memories!
ID:	428954Click image for larger version
ID:	428955Click image for larger version
                        • #72
                          History of Arado since 1975.
                          • #73
                            I didn't know that had so many models. I've only heard of the 120(B), which I have one.
