"Beyond" TGSL ....
  • Aziz
    Hi Aziz,
    sorry if I miss something.
    Soundcard usually have one signal input (Line In). You lead two signalls ("Lout" Signal S and "Rout" Reference R) to soundcard Line Input.
    Presume that those Line In have to be stereo?
    So "Lout" and "Rout" mean left and right channel of Line In?
    How important is corect connection in other words: can both channell be exchanged by each other or not?
    yes, you need a stereo sound card.
    Lout -> Sound card line in left channel
    Rout -> Sound card line in right channel
    Yes, you can exchange the channels. Your software should know, which channel is what.
  • Aziz
    Hints For A Digital VLF Detector Software
    Some requirements and comments on the digital laptop VLF detector software:
    - Make it frame based: a bunch of samples will be acquired and then processed. It is convenient to use power of two length frames (for FFT transforms). 512 or 1024 is a good starting value.
    - Store the frame buffers in a larger buffer for a larger time constant algorithms (filter, lock-in amplifier)
    - Use a Fast Fourier Transform (FFT) algorithm. You will need it as a phase shifter, filter, etc. It's not efficient but quite simple to do it this way.
    - Make adjustable time constant parameter for the digital lock-in amplifier. Increase in time constant increases the signal-to-noise ratio and hence the sensitivity. A high time constant parameter lowers the detector response (pin-pointing with high sensitivity).
    - Make an auto-ground-balance (tracking) algorithm.
    - Make a motion/non-motion detection processing
    How to phase shift a time-domain signal? (particularly for the quadrature-phase TX reference)
    R(I) (reference in-phase samples vector)
    - R(I) -> Complex FFT -> Power spectrum (complex I/Q output)
    - Power spectrum -> Amplitude and phase spectrum
    - Modifiy amplitude spectrum for filtering
    - Add +90 degree or PI/4 (grad/rad) in the Phase vector spectrum to all components except the DC component (index=0)
    - Amplitude and phase spectrum -> Power spectrum (back conversion)
    - Power spectrum -> complex invers FFT (back transformation)-> R(Q) (90 degree phase shifted and filtered)
    All what we did is a pure re-sampling of the time-domain signal but it's phase shifted and optionally filtered.
    For the digital lock-in amplifier, you have then:
    Signal S (RX), coming from sound card, optionally filtered
    Reference R(I) (TX), coming from sound card, optionally filtered
    Reference R(Q) (90° phase shifted R(I), computed)
    Lock-in:
    S*R(I) (mixer) -> low-pass filter -> I (channel X)
    S*R(Q) (mixer) -> low-pass filter -> Q (channel Y)
    S, R() is a vector of time constant length
    From the complex I/Q channel, the amplitude M (rms value) and phase P can be calculated easily:
    M = sqrt(Q*Q + I*I) (rms magnitude)
    P = atan(Q/I) (Phase in radiants -> make it degree if you want)
    P = atan2(Q, I) (better c math function for corrent radiant treatment)
    Ground balance, coil, circuit dependent phase shift corrections? Well, correct phase P before processing it.
    After processing M and P, you have lot's of informations for a digital sound generator. Put it to the sound card output to hear your detector screaming.
    That's it. This is just a simple way to start with. Later, advanced techniques can be used to process also the TX response for a better ground balance.
    Cheers,
  • WM6
    Just some comments:
    If the sound card is not capable of sampling at 96 kHz, the oscillator frequency should be lowered increasing either the coil inductivity or the resonant tank capacitors (CRX/CTX). If possible, a 24 bit sound card should be used. But it should run with 48 kHz/16 bit sound cards as well (reduced performance).
    Now all what you need is the software and the coil + active circuit board shown above.
    Hi Aziz,
  • Aziz
    Just some comments:
  • Aziz
    Hi Nicko,
    Originally posted by Nicko View Post
    Can I make noises here about the possibility of using an ATmega/WinAVR/GCC/AVRstudio4 combo (all free) instead of a laptop with VisualC++ or whatever? Or are you running a Linux distro with GCC?
    It would be easier to lug around than a laptop and the newer ATmega32s are very powerful. Further, they support pretty much all the features of GCC - its a cool toolchain. AVRs are, IMHO, much better at supporting C & C++ than PICs - I used to be a PIC aficionado, but switched sides about 3 years ago when WinAVR got so much better.
    Cheers
    you can forget any micro controllers or even DSP's! They aren't powerfull enough. The Atom processor in the Netbook for instance delivers enough number crunshing support to make a very easy but powerfull digital VLF detector. The presented solution is the best and easiest way of trying a digital VLF detector.
    I am using just the Microsoft Visual C/C++ for the implementation. No Linux, no µC board, no problems at all. And it uses the most used platforms. There are some open source projects in the internet regarding implementing the sound card. They can be used to start with (Linux or Windows, what you prefer).
    I promise you all, the final implementation will beat any VLF detector in the world. You all haven't seen the power of digital lock-in amplifier and it's noise immunity at all.
    The latest ideas will solve the arised problems of my previous experiments.
  • Nicko
    Hi all,
    this is the current version of the purely digital version of a VLF hardware implementation using a sound card and laptop (netbook). The software is not included (hell, it's still an experimental code and even not finished yet).
    Cheers
  • Aziz
    Promissed Spice Files and Schematics
    Hi all,
    Small changes in the RX amplifier gain and reference gain should be done to meet the sound card input specification.
    With the new Netbook computers and a 9V battery block for the circuit (drains < 10 mA), an one-day-detecting should be easily possible (using the internal sound card of the computer only).
    The software should implement a complex digital lock-in amplifier, which extracts from the input signals phase and amplitude relationship of TX/RX coil configuration. Furthermore ground effects, which also affect the TX voltage, should be taken into account (information is there and is detectable).
    I will work on the software as time allows.
    Cheers,
  • simonbaker
    I stand enlightened and entertained. The resemblance is uncanny...
    -SB
  • Nicko
    I don't know that reference, but I take it I'm not alone...
  • Qiaozhi
    SB
    Hitchhiker's Guide to the Galaxy?
  • simonbaker
    What colour? (re:HHGTTG)
    Cheers
    SB
  • Aziz
    Schematics Changed Slightly
    Hi all,
    now the new board is more tested. But I am not happy with the hardware phase shifter at all. The phase shifting pot (GB pot) is changing the input impedance slightly and this changes the reference TX signal amplitude at the output slightly. Something I wouldn't want to have it. Otherwise, I have to reduce the TX oscillator signal output impedance, which is not good to increase the load of the LC oscillator for stability issue.
    So let's get rid of the hardware phase shifter totally. Let's mod it.
    I will replace it with a simple inverting amplifier, which also reduces the high input voltage of the TX coil (capacitive voltage divider gone, input impedance increased, gain < 1). The phase shifting (GB setting) will be done purely digital in the software.
  • Nicko
    ...However I must reinvent the wheel. A personality flaw, too late to change.
    Anyone need some wheels?
    Cheers
  • Aziz
    Wiring Finished
    Hi all,
    the test board is almost finished. The LC oscillator is running and observed at oscilloscope: perfect (low distortion) sine waves at 28 Vpp between coil ends. I did not have all the parts so I have taken similar parts.
    Total power consumption: max. 12 mA (at 13.8 V input)
    TX reference output: 1 Vp (2 Vpp)
    The rest will be tested soon.
  • Aziz
    It seems like for (1) the best thing would be to both drive and sample the TX signal and you could really see the effect of the ground and maybe take it out of the RX signal or whatever. I think that's what you were doing originally???
    Anyway, whatever you cook up will be interesting fare for consumption....
    -SB
    No, I did not do all variations.
    But you rised some good ideas! Yes indeed, it could be very useful to cancel the ground effects totaly.
    I have some food for the coming days.. thanks.
