multi pulse orbit
    Ok ,thank you !
      In the link below you can view the new video tests made with Nexus Standard SE.
      http://www.nexusdetectors.com/videos.html
      good detector! but this is not advertising? or is ?
        Orbite, nisi ga razumeo.
        Ovde na Geotechu postoje razliciti forumi izmedju ostalog i forum namenjen slobodnom reklamisanju svih aparata koji se prodaju, bilo tvornickih bilo iz kucne radinosti.
        Forum se zove Free Advertising forum. Ako pogledas u taj forum, videces, da se Nexus reklamise tamo a ne u Tech forumu.
        Ako nesto prodajes, kupujes ili menjas opet imas forum namjenjen bas tome. Zove se Buy-Sell-Trade forum.
        Ako pak imas nesto za izmjenu iskustava, zelis predebatirati odredjen tehnicki problem, zelis objaviti neku samogradnju, sa shemom i stampanom plocicom i drugim uputama to onda objavis na Tech Forumu. Tech forum nije namjenjen pukom reklamisanju aparata.
          In English, please.
          Although I suspect you've probably said the same thing I am about to post.
          Orbit - The Nexus link you have posted is already in the Free Advertising forum, and was placed there by Nexus. You can also advertise your own detector there.
          I know there is often a thin line between what can be considered advertising and what is a project. For example, Silverdog supplies blank PCBs and kits for some of the projects here, and you might consider this advertising. However, these projects are mostly open-source, and Silverdog is supplying a useful service for other members. In some cases the project is not completely open-source, but contains some IP such as source code, and the software is supplied in the form of a hex file. This is also ok.
          As I said before ... I only mention this because another member complained that your post was blatant advertising. I would suggest placing a post for the Multi-Pulse in the Free Advertising forum, and if anyone wants to discuss the detector with you, they can do so here.
          I'm sure there are many other examples of surreptitious advertising in several of the forum threads, but we only ask that you don't abuse it.
            Thank vm6! ok ok I apologize I understand ,sorry!!
