pps have some minor advantages at these frequencies. But the cost is a big factor.
I used them in sythesiser loop filter one time and they gave the best performance.
they have about the lowest loss, ( tan delta ) I think I saw them in an XP machine,, could be mistaken.
They can melt soldering them too if your not used to them especially the sm ones
general polycarbonate or polyester are fine as Koala says, the supplied ones in Silverdogs kit work fine too
Had a crack with the deus in sea yesterday got nowt, one coke can about 8" down.
Loads of 80s ring pulls in the dunes to 7 or 8" plus a couple of coins off the sandy bit where people lie on in front of the dunes
IDX-PRO+VDI
Just the regular POLY FILM Green Blob Caps will be good enough ?
Originally posted by Koala View PostYes.
The more stable the capacitors the more stable and less drifting your detector will be
I used polyester for mine except for the polarized ones around the PSU and is fine
Two of the caps on the original Whites board were 1% can't remember which two they were see if I can look it up for you.
Sorry no idea. Quick Google search came back with nothing.Originally posted by jlsilicon View PostSo how about the CTX3030 COIL with 1KHz to 100KHz capability ..
Does anybody know the specs for it - Inductance, Windings, Caps ?
How is this done ?
Do you have a CTX 3030 coil already as the cost on eBay would be about the same as a 950 BlueMax
How is this done ?
Actually, I tried a 2n3819 across the coil with a few resistors - with the 5534 still attached.
The 3819 seemed to give a smoother and a lot more dramatic results
- according to my Datascope,
than the 5534 results.
According to my calculations, the 5534 opamp filter allows the pass through Band between of about 1KHz to 200KHz.
Does this calculate right ?
I used Ropcsika component list post 902Originally posted by jlsilicon View PostWhy is the Gain Resistor 170K on the 5534 ?
- Why not use 1M resistor ?
How about replacing 5534 with Opa627 or Opa637 ?
Any improvement with this - do you think ?
ic's: u1 5534
u2 cd4066
u3 lf347
u4 lm393
u5 lm358
u6 lm358
u7 lm393
u8 lm393
gives nearly 40cm with a 27DD coil on a old copper UK 2p in the air. and 100% stable. don't think you can squeeze any more out of this design and still be usable in the field.
the 180k gives 45dB Av
Any more would saturate on big targets, have instability problems, have dc offset issues? boost mains pickup etc
Just checked an original board none of the capacitors are 1% it was two resistors that were 1% R47 and R48Originally posted by Koala View PostYes.
Yes.Originally posted by ampirate View PostIf I am building this board from scratch,
- is there any specific type(s) needed for the Caps ?
