IDX-PRO+VDI
  • notron
  • notron
    The interesting thing is that the board works with the antenna 75 turns of 0.6 for the transmitter and 130 -140 of 0.25 adjusted for RX.GEB wonderful and everything is great but when you hang 9.5 "White's antenna and things go wrong.
    She leaves ditektno 6.5 kHz but no primer potentiometer can adjust phase, pinpoint cutting non-ferrous metals. Please let someone climb scheme goes en how.
  • Schatztaucher
    I think I read 6,5 khz
  • notron
    At what frequency work unit?
  • shansov
    marking of capacitors 1mkF?
    which cable can be used for the coil?
    Thank you.
  • notron
    Hello, I came to the plate and dish antenna have White's Spectrum XLT but can be adjusted GEB. Do you have any idea what's going on?
    The scheme worked with Spectrum XLT antenna? How do I set it up ?
    Think You
  • 6666
    here is a nice simple little calculator for playing with coil values for this project
  • 6666
    I thought the Garrett 150 already HAD TID....OH I see, you want one that actually WORKS!!!
    yes you got it
    would anybody like to take a guess as to which other brands and models of metal detectors the Vdi module would work with ?
    thanks
  • Schatztaucher
    coil-problems
    good evening,
    I have problems with the coil. Are the values ​​in the threat to the original coil or to the dd.
    would be great if someone could say something more precise about the building. the exact size of one d....etc.
    TX wire from 0.70 to 35 laps - 0.587 mH - within 1 mF capacitor
    RX wire from 0.15 to 270 laps - 35.6 mH - 0033 mF condenser inside
    regards, marc
  • shansov
    tell me. at winding RX wire from 0.15 to 270 laps. inductance has turned 35.6 mH, the resistance of 150 ohms. why did it happen?
  • Sean_Goddard
  • 6666
    elbombaci
    do you think the VDI module would work on garrett ace 150 ?
  • Schatztaucher
    i read that burner 5 is ok for the 16F88. I do not know whether the works.
    I'm building it when I know more about the coil and the parts I ordered.
  • Schatztaucher
    DIY progammer+software
    i found some programmer with software on a german site. might be interesting for some.
    pic: Programmiergeräte
  • der_fisherman
    Possibly an alternative PIC?
    Originally posted by detecto View Post
    Wich programer i can use for programing PIC16F88?
    Can i built epic programer from second page post #31
    Is he working good?
    I was recently wondering, just how much bandwidth is needed for the VDI Unit that Holyuser (I believe it was him, apologies if I am wrong) designed and made? Because if say a PICAXE chip was fast enough, there is no programmer needed, just a serial or USB port cable and its possible to reprogram "in situ" so to say.....so a change of function could even be made in the field provided a laptop was available!!
    The PICAXE chips run basic, but up to 40Mhz, so it could be possible, but only Holyuser could say for certain.
    The chips are exceedingly cheap and very flexible in usage, anyone needing more info can ask and I will send them a good link to get them started.....By the way, all software and manuals are all totally free to download as the company Revolution Education designed them with financial assistance from the UK Government.....
    Andy
