IDX-PRO+VDI
  • eduardo1979
    Originally posted by h9361 View Post
    Thanks.
    I have a problem, i used two tones pcb ( attached).
    First, i remove ferrite in one tone mode using GB pot.
    Then, i switch to two tones but i can not remove ferrite in this mode.
    I think GB is not working on two modes and it is very very unstable on ground and we have Continuously IRON tone!
    I think schematic of the two tones is not correct and need to be edited.
    Has anyone been able to solve this yet?
Name:	2 Tonesnew.png
    First, did adding the 4.7V Zener diode solve the overload problem? The PCB layout corresponds to the IDX PRO 2 TONES schematic, except for the CD4060, which performs the same function as the CD4024. If this schematic doesn't suit you, you can use the CLASSIC 3-2 TONES schematic.
  • pechkata
    Thanks.
    There should also be a third tone—a background sound.
  • h9361
    Originally posted by eduardo1979 View Post
    Hi.
    A large part of this problem is solved by adding a 4.7V Zener diode in parallel with resistor R22, connecting the diode's anode to pin 1 of U3 and the diode's cathode to pin 2 of U3. Let us know how it goes.
    I have attached the diagram with the modification.
    Thanks.
  • eduardo1979
    Hello dear Carl
    My IDX is working nice with my coil but there is still a problem.
    Audio of My IDX will be cut off if i close any medium or big size targets to coil (5-10cm)!
    For exp, i have not any audio for a 10 cm (diameter) steel bowl from 10-12cm distance.
    I checked it on scope, i have a big overload.
    Do you have any suggestion for solving this?
    Click image for larger version  Name:	476634134_611869781703955_7881267658661431449_n.jpg Views:	127 Size:	282.2 KB ID:	451859
    Hi.
  • irmasirmas1234
    Skema PCB metal detektor IDX pro 2 tone
  • Carl-NC
    As Orbit says, all detectors will overload at some point. Normally, the gains of the various stage are set up so that nothing overloads on the worst expected ground. After that, reducing the RX gain just reduces sensitivity. If you are not overloading on ground then I would leave the gain as high as possible. If a target overloads it, just lift the coil.
  • pito
    check what going on on U6 output and Q3 base when sound is despairing
  • h9361
    What you described is normal for idx! Even factory idx devices with the original coil have an overload effect on targets that are 10cm and larger near the coil! This is absolutely normal behavior for Whites idx Clasic 3, Whites ID.. Don't worry about it!
    Thanks.
    I think this overload distance is very high.
    For exp, i have an overload for smoke foil from 10cm distance.
    Do you think i should decrease Gain preamp?
  • Orbit
    Hello
    Dear Orbit
    Do you have any suggestion for #4398 post?
  • h9361
    The current of the collector should be a little higher in the case of bst 52 is 1A darlington so that the transistor absolutely does not overheat and the speaker does not break. But I think Karlo's proposal might be better..
    Hello
    Dear Orbit
  • h9361
    -VB
    Dear Carl
    Do you think the overload is because of more gain in preamp (R2/R1=180)?
    Do you think i should decrease this to lower like 150 or 120?
  • h9361
    -VB
    Hello dear Carl
  • Carl-NC
    In your LM386, gnd is the pine 7 or _VB?
    -VB
  • Orbit
    You right, my noise is low by the changing.
    I can not understand bst 52.
  • h9361
    An 8-ohm or 4-ohm speaker might be louder. However, the speaker is DC-coupled and you run the risk drawing a lot of static current. Here is a simple circuit I used in ITMD3 projects:
    Click image for larger version  Name:	image.png Views:	0 Size:	17.0 KB ID:	451417​
    In your case, VTX is Vbatt, VCC is your "+" supply, and Q3 (your Q4) can remain as an MPSA13 although a non-Darlington NPN might give a little more loudness.
    Very thanks dear Carl
    GND is generated in IDX by u7-pine 7.
