to integrate in a linear way
HI Aziz,
I'm using the mobile phone, but only to display conductivity and signal.
Using it as a convenient LCD replacement basically.
I have found the processing can all be done at the lowest level and the real important stuff is the front end..eg the way you are measuring the pulse widths.
My system uses only 2 pulse widths, called V1 and V2. (your proposal uses 4).
They are being added up (integrated) through a constant current (see attached).
I happen to be using 35 pulses, and then taking a measurement on the capacitor.
After the measurement, the capacitor is discharged and the pulses start again.
Note, the results (attached).. you will find the ratio of the pulse width changes are constant for a particular conductivity..i.e, When v1 (pulse width1) and v2(pulse width2) are plotted on a graph, they make a straight line..and the slope indicates conductivity. This tells me that the constant current method is good, and the system works as expected.
Anyway, the signal is very small at distances greater than 20cm, so all the processing power in the world can not help determine the target in this case...it is just a small beep, which could be almost anything.
I have really been concentrating on getting greater front-end performance..deeper, and less noise.
One way is to increase the pulse width, or take more samples..
Regarding the Bluetooth I'm using RN-42 from sparkfun...
HI Aziz,
