Burning ATtiny25
Hi 6666,
I have used a cheap chinese isp programmer to reprogram Atmega168pa.
Here's a link to the cheapest one I have seen.
By the way they will program attiny25 also.
link..http://www.hobbyking.com/hobbyking/s...occessors.html
Cheers John
Hello 6666Originally posted by 6666 View PostI have ordered a USB burner for the ATtiny25 project listed here
in the mean time there is a whole host of simple serial and parallel
burners and software on the net
Has anybody successfully used any to burn a ATtiny25 ?
Have used http://www.lancos.com/prog.html works nice...
Best regards
ApAttached Files
Originally posted by ApBerg View Post
Oops......... think Pony prog can not work with USB programmers...sorry 6666 ...
I use the http://www.pollin.de/shop/dt/MTY5OTg...1_Bausatz.html
johnandles
thats very similar to the burner i have ordered
in the mean time I have been playing a bit with a simple
Bascom burner and Avrdude with a GUI interface called Avr burn-o-matt
and today it appears to have worked after much trying
at least the text report says it worked
will test the ATtiny25 and report back
Hello 6666,glad you are getting it sorted.Originally posted by 6666 View Postjohnandles
Also the firmware that you are flashing is there some Ground balance?
Cheers
John
I looked at the ~$20 USB programmer, not bad and I'll likely order one. However as I already have AVR Studio and AVR Toolchain D/L'ed and an ATtiny13 I want to program my only problem is the wait for delivery. Is there a DIY USB programmer project I can build. Going to order a tiny25 to try this detector but had this tiny13 I wanted to build a different circuit with and have been researching the best route for burning these devices when I came upon this very interesting project mentioned above: http://www.geotech1.com/forums/showthread.php?t=17507.
This is my first adventure into AVR territory, I have been working with PICs for a long time.
Yes, Dean Camera made an AVRISP MKII clone several years back. He went open with his design, and you are free to build your own USB clone from scratch: http://www.fourwalledcubicle.com/AVRISP.phpOriginally posted by Dr Vel View PostI looked at the ~$20 USB programmer, not bad and I'll likely order one. However as I already have AVR Studio and AVR Toolchain D/L'ed and an ATtiny13 I want to program my only problem is the wait for delivery. Is there a DIY USB programmer project I can build. Going to order a tiny25 to try this detector but had this tiny13 I wanted to build a different circuit with and have been researching the best route for burning these devices when I came upon this very interesting project mentioned above: http://www.geotech1.com/forums/showthread.php?t=17507.
Personally, I wouldn't bother making a clone since these devices can be found cheaply on ebay.
Just make sure to get an "AVRISP MKII" or other clone since you want Atmel support. Some, like the USBASP clone are really cheap (less than $5), but are not supported by AVR Studio. These cheaper clones rely on buggy proprietary software that some times come with driver issues.
Also, if you're new to the atmegas, you can build your self an Arduino board (http://arduino.cc/en/Main/ArduinoBoardUno). The beauty of this second option is that you can use the Arduinos as your main development board in addition to using them as an ISP programmer as an option ( not both). Scroll down for the Eagle files in addition to the schematic.
The Arduino boards can be transformed into an ISP programmer only after programming them with the necessary software.
Don't be shocked if you go the Arduino route. I had some experience using the Atmel processors and their free toolchain before checking out the Arduino. After getting their hardware, I think I felt insulted by how easy everything worked. Most pic guys never go back once they have had sometime with the platform.
This is what works for me, to burn a ATtiny25, from my desktop PC.
see other post for results of testing
Simple parallel port burner called Bascom also known as Dontronics DT006
works for me with a cable one metre long.
Two pieces of Software are needed
AVR Burn-o-matt, (this is great)
this is a GUI for Averdude which is a horrible command line program,
but the AVR Burn-o-matt makes it easy to use.
You also need to install WINAVR, this contains the Averdude program, (and other stuff)
NOTE: In AVR Burn-o-mat, you must select the correct directory that WINAVR is in
so it can find Avrdude
and also select the port.
Load your hex , burn it
alter your fuses, burn them
you will see a text report
You can just use the Avrdude program its self
good luck
