after I tuned these are performance
deeper as Pirate black-devil, or as good
I do not understand detector noise about pirate ?
Aţi dorit să scrieţi: tu jest bolnav la cap cuscre ?
Introduceţi text ori o adresă de site web sau traduceţi un document.
Anulaţi
So even you are not able to do something better?
Hi Lasser,
Would you describe and share with us a little more detail what changes have you done?
It worth to share youre xperiences!
Looking the movie I can said, that achieved result is impressive!
Превод от: английски
Въведете текст или адрес на уебсайт или преведете документ.
Отказ
postignatiyat rezultat e vpechatlyavashtAlpha
Отказ
Hi lasser,
sorry for the late answer, I was busy the last week.
thank you for the youtube video.
I repeat: What do you want to find ?
For goldnuggets you may use a pulse induction with 10cm coil,
for treasure chests you can buy the Jeohunter with 1m coil
or for pinpointing you should get the Garrett Pro Pointer and
modify it.
In the middle range your Pirate Black-Devil (I like this name
seems to be unbeatable.
You also can try to get a Pulse Induction with 2m frame.
The cheapest solution for you would be to homebrew (built it yourself)
a special oval (eliptical) coil that you can use with
the Pirate Black-Devil.
Try dimensions 35x60cm double D (DD). These are two small
Ds. Or try 30x45cm for smaller stuff. Try to use more windings
as in original coil design for higher inductivity.
Try to inform the producer of the Pirate Black-Devil about
your modifaction so he can improve it. If you need money
perhaps he will give you good money for this mod or you
get the big coil for free. Any more questions?
