Affordable pocket DIY "cheaposcope"
  • Affordable pocket DIY "cheaposcope"
    Affordable 200kHz (1Ms/s) DIY (with SMD parts pre-soldered) pocket-scope with improved vertical sensitivity (5mV/div):
    Very handy for detector builders terrain check and tests, due 8-10V battery power supply:
    http://www.banggood.com/Orignal-JYE-...FcFAGwodlfYIFw
    my dream to have handy pocket spectrum analyzer for same price
      Looks like an update on the DSO138 which I built and works well.
      Noticed its out of stock.
        Model DSO 096 from same producer (JYE Tech) is equipped with
        FFT function and can act as Spectrum analyzer and 20 MHz frequencymeter.
        It has much better bandwidth (5Mhz compared to above 200kHz), but not so good vertical sensitivity (10mV/div compared to 5mV/div).
        http://www.jyetech.com/Products/LcdScope/e096.php
        http://www.jyetech.com/Products/LcdScope/FFT_01.jpg
        About double price (you can negotiate price - Make Offer) on eBay:
        http://www.ebay.com/itm/Handheld-Oscilloscope-Improved-Model-Small-Pocket-Portable-Scope-DSO-Probe-USA/150746423711?_trksid=p2047675.c100005.m1851&_trkpa rms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3 D38530%26meid%3D3aeb6627ffa84241b1c8afa93b8e08de%2 6pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D1607876249 42
        Yes it is updated DSO138 (DSO150).
          I've had the DSO Nano 201 model - it was fairly accurate for the price (~80$), well nothing like bench-top scope, but most importantly the interface was really awful so I've sold it.
          I'm done with cheap DIY type scopes or used scopes older than I am, I may need to suggest a Christmas gift idea to my girl, some fancy-fancy DSO would be appropriate gift
            thanks Wm6, but WHY they all are Number of Channel: One?
            its bad (
            i must have 2 channels, with possibility turn out sync on both (Z input). so i get godograph or in your world
            this called VDI.
              I built the DSO138. For the Money it does what it's suppose to do well. Well they lied about the 200Khz . Signal trace is un usable after about 100khz. Measures Freq and that works fine. Funky Lexen Case is trashed first time you drop them. LOL Wish it was two channel. 10uS allows you to Check PI Sampling Just. But it works. This one looks like it may be a bit more handy then the buttons on the DSO138.
              These little puppies are handy for measuring Inductance too.
              http://www.banggood.com/DIY-M12864-G...l?rmmds=search
                its bad (
                so i get godograph
                Yes one channel.
                For little money you get a little music.
                But you ask for spectrum analyzer first, not for godograf usability.
                It can act as spectrum analyzer.
                Godograf ask for something different options.
                I don't know cheap Digital storage oscilloscope equipped with Z-input (Z-input belongs more to CRT-scope technologies).
                You can get frequency sweep at one channel Spectrum Analyzer too, in contrast to godograf circular phase view, here is XY view.
                Try, maybe it can satisfy your needs.
                  pocket size
                  includes:
                  -2 channel Osciloscope
                  -generator
                  -spectrum analyzer
                  -wobbuloscope
                  -multimeter
                  -available connection to PC
                  http://serwis.avt.pl/manuals/AVT2999.pdf
                  https://sklep.avt.pl/avt2999.html
                  kit cost ~40euro
                  or made by yourself, documentation is freeware:
                  http://forum.elportal.pl/viewtopic.php?t=11437
                    thank you so much. nice device i believe. must teach the polish? LOL
                      Originally posted by reiv View Post
                      pocket size
                      includes:
                      -generator
                      -spectrum analyzer
                      -wobbuloscope
                      -multimeter
                      kit cost ~40euro
                      Conceptually excellent, but 50mV/div vertical sensitivity is on the border of usability (par example for coil tuning).
                      I hope this will be improved by factor of 10 (to 5mV/div or even better).
                      To fully exploit great concept of this instrument in field of PI detectors (par example observing changes of PI coil
                      resonance) analog bandwidth should be over 1MHz (better over 2MHz).
                      Design with great potential in field of MD DIY builders - after some further improvements.
                      Congratulations for nice approach.
                        This project is from 2011, and to be clear I`m not the author. Made this unit few years ago, and I`m happy with this. Using in VLF/PI project, nulling coils also (if You want more precise reading value of voltage at coil balancing just switch to multimeter mode) . I powered this by li-on battery from a sell phone and works pretty long, soe auto mechanical diagnostics sensors for example is also available.
                        For sure this is not HI END performer it`s just Xmega inside, but for basics operations it works. Author it`s not interesting any more with this project soe there will by no any improvment. Bigest problem for any upgrades are noises in circut. Some day he wrote that he planning to change Xmega by STM, but his last post is from 2014...
                        Here is my unit:
                        https://drive.google.com/open?id=0B-...1Z2a2xiYWI2aUU
                        https://drive.google.com/open?id=0B-...Dk1VGlOdFpXMlU
                        https://drive.google.com/open?id=0B-...FNtUlI0UlVwVFk
                        https://drive.google.com/open?id=0B-...2Y1TTNVLTFGVFE
                        And short movie using Analayzer to find resonase freq. at VLF coil (connected to PC):
                        https://www.youtube.com/watch?v=J43iCm1oLEI
