Search Result
148 results in 0.0045 seconds.
Keywords
vco pi
Members
Tags
  • Ray Huffman
    Guest replied to VCO update
    Re: VCO update
    Many years ago I worked for a company that made sesmic sensors for oil exploration. We had a screened cage that we tested the preamps for the sesmic sensors. These discrete preamps were touted as have 100db gain for the low signals coming from the sensors. It worked for...
    See more | Go to post
  • Carl
    Guest started a topic Update on on new PCBs, and request for input
    OK, my plan to get new Hammerhead PCBs got delayed a little. I had a new PCB layout ready to go, back in January, and home-etched one to test out... good thing, too, found a layout error. OK, fixed that.
    But, I never liked the VCO audio I used, not enough frequency range, which is a fundamental...
  • Carl-NC
    Guest replied to PI-1 Question
    Re: PI-1 Question
    No, I think it can be done with one. Trigger off the secondary sample pulse, and just use the 555 to set the pulse width. As long as it occurs after the secondary sample (i.e., falling edge), it should be OK.
    Let me see what I can come up with. Right now,...
  • Joe Johnson
    Guest started a topic PI-1 Question
    PI-1 Question
    I built the PI-1 using non-VCO option. Twice in the article, Carl mentions that with this option you can have a problem with current spikes from the speaker disrupting the front end. I am experiencing this problem. Carl says both times to delay the chopping signal out of the sample period....
  • Carl
    Re: PI-1 Question
    Well, I just probed my current board, and the chop pulse isn't what I thought it was. It's much worse... a wide pulse with one edge at the end of the first sample and one edge at the beginning of the secondary sample. I will have to look at this some more... possibly...
  • Carl
    Guest started a topic New PI-1 PC board, surface mount
    Here is the first draft of a new PC board I've worked up, this time using surface mount devices. It's 2 x 2.3 inches, a little less than 1/3rd the area of the old board.
    The major ICs and most discretes are SMD, using SOIC and 0805 sizes. Having hand-soldered down to 0402, I think 0805...
  • Carl
    Guest replied to Ordering PI-1 pcb
    Re: Ordering PI-1 pcb
    $10 includes shipping. My preference is for the VCO audio. I would recommend keeping the threshold and sample delay on external knobs (and maybe a toggle switch for autotrack, but only if it's primarily surf-n-sand), everything else can be board-mounted.
  • Carl
    Guest replied to CarL: Need your opinion?
    Re: CarL: Need your opinion?
    Holy smokes, what a question! Since I haven't used all the detectors out there, I surely can't answer that. And most people will immediately point out, that what's best for coin hunting, nugget hunting, relic hunting, and surf hunting, might all be different...
  • Robert Hoolko
    Guest started a topic Digital PI schematic
    This is just an example to show what parts of the PI circuit could be replaced by a micro controller. I am not claiming that this design would actually work as drawn.
    I just removed the parts of the original schematic whose functions could be performed by the ADuC812...
  • Robert Hoolko
    Guest replied to Digital PI schematic
    Re: Digital PI schematic
    Pawel
    In this chip the timer auto reload is only 8 bits so the frequency would not be low enough for VCO. I would have to add external parts.
    The chip would be fast enough for VCO if it did not have anything else to do, but I am afraid...
  • Carl
    Guest replied to Geotech PI
    Re: Geotech PI
    I might go with Geotech PI, was looking for something a little snazzier. Most of the snazzy names are used, Piranha being one of my favorites.
    Which supplies to use for the switches is usually determined by how the switches are used. My preference is to put...
  • alexis
    Guest started a topic My Pi project
    My Pi project
    Thank you very much for yours comments ,For the professional look ,it is easy with the Corel draw and a good box from Hammond (Canada).
    Two o three years ago ,i explain in 3 parts in the Forum of Eric, the fabrication of my coils with PVC tubing ,filling with sand and a hot gun .......and...
  • Carl
    Guest replied to PI Circuit from Carl
    Re: PI Circuit thanks Carl
    Russ,
    The whole concept of this PI design is "variable everything". It is intended to be an instructional platform for those who want to learn about basic PI detection.
    Variables include frequency, pulse width, sample delay,...
  • Carl
    Guest started a topic Precession Frequency - write it down.
    >There is a PI design on the market now - The VibraProbe. The selling points for it are:
    >- It vibrates when near metal, which makes it good for use with headphones (for the main detector), or near surf - so that you need not strain to hear a beep.
    I've...
  • Mark
    Guest started a topic Re: Trucks at 10 Feet and New Mag On The Block??
    - It's waterproof...
  • Carl
    Guest replied to Precession Frequency - write it down.
    Re: Suggestions for a 'pinpointer' design
    >- It vibrates when near metal, which makes it good for use with headphones (for the main detector), or near surf - so that you...
  • Carl
    Guest replied to Suggestions for a 'pinpointer' design
  • Mark
    Guest replied to Re: Trucks at 10 Feet and New Mag On The Block??
    - It vibrates when near metal, which makes it good for use with headphones (for the main detector), or near surf - so that you need not...
  • Mark
  • Carl
    Guest replied to Re: EUREKA Anomaly Magnetometers.
    >What would be interesting would be a pinpointer that has far better depth that the currently available products - specifically the ability to pick up a dime at about 3 inches, with a zero motion, all metal operation. None of the universal...
  • Carl
  • Carl
  • Carl
    Guest replied to Abbreviations
    Re: Abbreviations
    Here's a few:
    BFO: Beat Frequency Oscillator
    TR: Transmit-receive
    IB: Induction Balance
    VLF: Very Low Frequency (defined to be 3-30KHz)
    PI: Pulse Induction
