Playing with AI_Can AI help creating ferrous discrimination?
  • Playing with AI_Can AI help creating ferrous discrimination?
    After removing the cataracts from my eyes, I can see better again and started tinkering again with pulse induction detectors.
    I started by playing a bit with AI. below is part of my chat with AI. I noticed that I can include / invite others to the chat so I am posting this here. If someone would like to join the chat with AI please manifest your interest.
    I would like to post the AI discussion here, but it is probably best to reduce the discussion to a few extracts.
    1. What your TX system really is
    You do not have an LR step system.
    You have a distributed RLC resonator whose parameters change dynamically during the pulse. During the 50 µs “flat” phase
    • Current ≈ 1 A
    • Magnetic field is quasi‑static
    • Targets reach a steady induced state
    • Iron domains settle into a biased magnetization state
    This phase is excellent for setting initial conditions. During the flyback / reversal
    When you open the MOSFET:
    • The inductor current charges distributed parasitic capacitance
    • Voltage rises until current reaches zero
    • Then the LC system reverses current direction
    This is not a clean LC oscillation — it’s:
    • Nonlinear (MOSFET capacitances are voltage‑dependent)
    • Geometry‑dependent
    • Strongly coupled to the target
    The important consequence:
    Your target is part of the resonant system during the reversal.
    That’s why you can see 1 µs time constants at all. 2. Why parasitic‑C flyback is actually ideal for discrimination
    Most PI systems try to eliminate parasitics.
    You’ve discovered (correctly) that embracing them gives better information.
    Here’s why. Copper vs iron during your reversal
    Copper sphere
    • Eddy currents oppose the rapid field change
    • Acts like a purely dissipative, linear load
    • Adds effective resistance and inductance
    • Response is:
      • Linear with amplitude
      • Symmetric with polarity
      • Memory‑free
    Copper mainly damps the resonance. Iron sphere
    Iron does three things simultaneously:
    1. Eddy currents (like copper, but higher resistivity)
    2. Field‑dependent permeability
    3. Domain relaxation and hysteresis
    During the reversal:
    • Effective inductance changes during the pulse
    • Energy is temporarily stored in magnetization, not just currents
    • The LC trajectory is distorted asymmetrically
    Iron doesn’t just damp — it warps the phase space. Why τ alone is insufficient (and misleading)
    You already noticed this:
    A larger iron sphere can mimic the τ of a smaller copper sphere.
    That’s because:
    τ∼μσa2
    But τ is only one projection of a much richer response.
    The discrimination lives in:
    • Early‑time curvature
    • Polarity asymmetry
    • Amplitude dependence
    • Residual flux memory
    All of which your system is already sensitive to. 3. How to tell copper from iron using your decay curves
    Given your constraints (1–2 µs earliest sampling), here’s what works reliably. A. Polarity asymmetry test (most powerful)
    Compare:
    • +1 A→−1 A
    • −1 A→+1 A
    Align the traces at the end of the flyback.
    Copper
    • Waveforms are near mirror images
    • Same decay envelope, opposite sign
    Iron
    • Different peak amplitudes
    • Different early‑time curvature
    • Often different late‑time tails
    This works even when τ matches. B. Amplitude scaling test
    Repeat at different current levels (or different flyback voltages).
    Normalize by ΔI.
    Copper
    • Normalized curves overlay
    Iron
    • Shape changes with amplitude
    • Early decay shifts earlier/later
    • Indicates μ(H) nonlinearity
    This is a smoking gun for ferromagnetism. C. Integrated pickup voltage (hidden memory)
    Even with AC coupling, you can compare relative areas:
    ΔΦ(t)∝−∫VRX(t) dt
    Copper
    • Integrated response converges to the same value every cycle
    Iron
    • Depends on history
    • Polarity‑dependent “missing area”
    • Indicates remanent magnetization
    D. Fit residuals, not τ
    Fit a single exponential to the late tail.
    • Copper → residuals go noise‑like quickly
    • Iron → structured residuals persist
    You’re seeing multiple relaxation processes in iron. 4. About your 1–2 µs sampling limit
    You’re already doing extremely well.
    At that timescale:
    • Copper eddy currents are still strong
    • Iron domain processes are just starting to relax
    That overlap is exactly why discrimination is possible.
    If you ever manage sub‑µs gating, you’ll see even more contrast — but it’s not required. 5. How to share LTspice simulations here
    You can’t upload LTspice files directly, but you can do any of the following: Best options
    • Paste the netlist text (the .cir content)
    • Paste screenshots of:
      • Schematic
      • Current waveform
      • Voltage waveform
    • Describe component values and topology (you already did this very well)
    If you paste the netlist or waveform data, I can:
    • Interpret the resonance
    • Identify which features are target‑sensitive
    • Suggest exactly where to sample for best discrimination
    One final observation (important)
    Your system is already operating in a regime where:
    The target modifies the TX waveform itself, not just the RX decay.
    That’s why parasitic‑C flyback works better than “clean” pulses.
    You’re not just measuring eddy currents — you’re probing electromagnetic phase space.
    If you paste the LTspice netlist or a waveform trace (even ASCII), I can walk through it step‑by‑step and point out exactly which features separate copper from iron in your timing window.
    here is a link to the AI chat https://copilot.microsoft.com/shares...MK19Sn7GzBxE6z
      Microsoft Copilot is AI built to help you get things done. Create, brainstorm, learn, and solve problems with AI chat that works across your day.
      SQUARE_WAVE_different timing.rar
        And here it continues:
        I’ll go straight to the physics that matter for copper vs iron discrimination in your topology, then explain how to extract that information from the decay curves you already have.
        1. What the LTspice plot tells us immediately
        From the waveform:
        • You are not operating in a simple LR or even clean LC regime.
        • The flyback is a parasitic‑dominated, under‑damped transient with:
          • Voltage peaking near 800–1000 V
          • A fast current reversal
          • Strong sensitivity to any change in effective inductance or loss
        This means:
        The target is modifying the TX transient itself, not just producing a passive decay afterward.
        That is exactly the regime where ferrous discrimination becomes possible.
        2. Why parasitic capacitance is actually your ally
        Using distributed parasitic capacitance does three crucial things:
        1. It shortens the effective excitation impulse
          → pushes energy into the 0.5–5 µs band where copper and iron behave very differently.
        2. It makes the system sensitive to ΔL during the pulse
          → iron changes μ dynamically; copper does not.
        3. It couples target response into the phase of the transient
          → not just amplitude or τ.
        This is why adding a “nice” external capacitor made things worse: it linearized the system and erased information.
        3. Why τ matching does not imply material matching
        You already observed:
        A larger iron sphere can give the same τ as a smaller copper sphere.
        That is expected, because:
        [ \tau \sim \mu \sigma a^2 ]
        But τ is only the slowest eigenmode of a much richer response.
        In your system, the discriminating information is concentrated in:
        • Early‑time curvature (1–5 µs)
        τ alone is insufficient — but τ plus shape is decisive.
        4. What differs in the decay curves (concretely)
        Copper sphere (any size)
        • Linear response
        • Polarity symmetric
        • No magnetic memory
        • Eddy currents only
        • Effective parameters constant during pulse
        Observable consequences
        • Normalized decay curves overlay for different amplitudes
        • +→− and −→+ transitions are mirror images
        • Late‑time decay fits a single dominant mode cleanly
        Iron sphere (even if τ matches copper)
        Iron introduces three extra dynamics:
        1. Field‑dependent inductance during flyback
        2. Magnetization relaxation after flyback
        3. Hysteresis / remanence
        • Early decay shape changes with pulse amplitude
        • +→− and −→+ transitions differ measurably
        • Integrated pickup voltage depends on history
        • Single‑τ fits leave structured residuals
        These effects survive even when τ is matched by geometry.
        5. How to extract discrimination with your 1–2 µs limit
        You are already sampling early enough. The trick is what you compare.
        A. Polarity asymmetry test (most robust)
        Overlay the post‑flyback decay for:
        • +1 A → −1 A
        • −1 A → +1 A
        Copper
        • Same shape, opposite sign
        Iron
        • Different peak, different curvature, different tail
        This works even if τ is identical.
        Repeat at different current levels or flyback voltages.
        Normalize by ΔI.
        Copper
        • Curves overlay
        Iron
        • Curves shift in time and shape
        This directly reveals μ(H).
        C. Integrate the pickup voltage
        Even with AC coupling, compare relative areas:
        [ \Delta \Phi(t) \propto -\int V_{RX}(t),dt ]
        Copper
        • Converges to same value every cycle
        Iron
        • Depends on polarity and history
        This is magnetic memory leaking through the decay.
        6. One subtle but important point from your simulation
        Because your flyback is parasitic‑dominated:
        The most discriminating information is encoded in the transition, not just the decay.
        That means:
        • Small differences in early‑time curvature (even before your nominal “decay window”) are meaningful.
        • You don’t need perfect gating — you need repeatable alignment.
        If you align traces at the zero‑current crossing or voltage peak, the differences become very clear.
        7. About sharing LTspice files here
        You can’t upload .asc files directly, but you can:
        • Paste the netlist text (LTspice → View → SPICE Netlist)
        • Paste waveform data (right‑click trace → Export data as text)
        • Post multiple screenshots showing:
          • Current through TX coil
          • Voltage across TX coil
          • RX pickup waveform
        Any of those is enough for me to analyze the dynamics precisely.
        Bottom line
        You are already operating in the correct physical regime for ferrous discrimination.
        The key insight is this:
        Copper damps the transient; iron reshapes it.
        τ matching hides that difference — shape, symmetry, and amplitude dependence reveal it.
        If you paste the TX current waveform and one RX decay trace for copper and iron (same geometry), I can point to the exact microsecond window where the discrimination is strongest and suggest a quantitative metric you can compute in firmware.
          Nice discussion. With a sinusoidal incident magnetic field the BH curve for iron looks like this:
          and results in a phase shifted and distorted target field. Non-ferrous targets produce phase shift but "no" distortion, so you can theoretically look at the fidelity of the RX signal to determine iron.
          For a pulse response it's a similar situation, except that it's the decay curve that is distorted with iron but is "not" with non-ferrous. So you can theoretically look at the linearity of the decay curve to determine iron.
          I quoted "no" and "not" because there are caveats. First caveat is that the early eddy response in a target is 'non-linear' due to the self-spreading of the eddy current. That is, it takes time for the eddies to push themselves out to the perimeter of the target, namely 1 tau. Here is a US silver quarter:
          The tau of the quarter is about 150us and it takes about 150us for the decay to settle into the expected single exponential response. If you take a bunch of samples (both early and late) you will get different values for tau. In a sinusoidal system, the result will be that the target will initially have a low phase that (in 1 tau) grows to a higher phase. Iron targets also suffer this same effect for their eddy response component, in addition to the distortion caused by their magnetic response.
          Second caveat is ground. Everything discussed so far (including with AI) is for an air matrix. Ground also causes non-linearities, not only BH hysteresis but also viscosity (time decay) effects. This will turn an otherwise clean-looking copper sphere waveform into a distorted waveform that starts looking a whole lot like iron.
          Ground effects are usually the bane of good metal detector ideas. Everything works well until the target is buried in real ground. I would get AI to start considering ground effects and see how much it really understands the problem. Also, get some real data of target responses with and without ground, for different depths in different grounds.
            Thank you Carl for your input. I agree, we are a long way from a working detector.
            At present I feel like "the dumb leading the blind". I need to give the AI much more information to work with, so that it can help me.
            I am going to try to add your answer to the AI discussion to help it finding the right path.
              I uploaded screenshots of the waveforms to the AI, but the answers are maybe too long to post here.
              Has anybody tried the link to see if they can join the AI discussion directly?
              Anyway, here are the screenshots:
                Here is the AI answer on Carl's post:
                See my thinking
                That’s a good expert, and they’re basically describing in words what you’ve been building toward in hardware.
                Let me tie their points directly into your setup and then push it one step further, including ground. 1. Linearity vs distortion in your decay curves
                What they call “fidelity of the RX signal” in sinusoidal systems is exactly what, in your pulsed system, shows up as:
                • Copper / non‑ferrous:
                  • After about one τ of the target, the decay becomes a clean single exponential.
                  • If you normalize by amplitude, the shape of the late decay is very stable.
                • Iron / ferrous:
                  • Eddy currents + magnetization → the decay is not a single exponential.
                  • Shape changes with amplitude and polarity.
                  • You get a “distorted” decay curve.
                In your language:
                “Look at the linearity of the decay curve to determine iron.”
                That’s exactly what we were circling: not τ alone, but shape invariance vs shape distortion under amplitude and polarity changes. 2. Early-time nonlinearity even for non‑ferrous
                Their first caveat is important and matches your intuition:
                • For a finite‑size conductor, eddies don’t instantly fill the object.
                • It takes about one τ for the current distribution to settle to the “simple” mode.
                • Before that, the apparent τ depends on where you look in time.
                So even a pure copper sphere or silver coin has:
                • Early-time “self‑spreading” nonlinearity (multi‑mode diffusion).
                • Late-time single‑mode exponential.
                In your system, that means:
                • If you sample too early relative to the target’s τ, you will see “distortion” even for non‑ferrous.
                • For small, high‑conductivity targets (short τ), your 1–2 µs window can already be in the “late” regime.
                • For larger or poorer conductors, your early window is still in the “multi‑mode” regime.
                So the discrimination trick is not “iron = distorted, copper = perfect exponential,” but:
                Iron stays distorted and amplitude/polarity‑dependent even when you’re in the late‑time regime for that target.
                3. Ground: the real spoiler
                They’re absolutely right: everything we’ve discussed so far is air matrix.
                Real ground adds:
                • Its own eddy currents (conductive soils).
                • Its own hysteresis and viscosity (magnetic soils, clays, laterites).
                • Depth‑dependent attenuation and phase shifts.
                Consequences:
                • A clean copper sphere in air → nice, almost single‑exponential late tail.
                • The same sphere in mineralized ground → the sum of:
                  • target response
                  • ground response (which can itself be nonlinear and time‑dispersive)
                So yes: ground can make a copper target’s decay look “iron‑like” if you only look at raw waveform shape. 4. What that means for your system design
                Given your hardware and timing, here’s the realistic path:
                1. In air / controlled conditions
                  • Use exactly what we’ve been discussing:
                    • Polarity symmetry
                    • Amplitude scaling
                    • Early/late ratios
                    • Single‑τ vs multi‑τ residuals
                  • This will separate copper vs iron very cleanly.
                2. In ground
                  • You need a ground reference:
                    • Measure a “no‑target” decay curve for that patch of ground.
                    • Subtract or normalize against it.
                  • Then apply the same tests to the residual:
                    • If the residual behaves like clean eddy diffusion → non‑ferrous‑like.
                    • If the residual still shows amplitude/polarity‑dependent distortion → ferrous‑like.
                3. Depth and τ
                  • For shallow, small, high‑conductivity targets (short τ), your 1–2 µs window is already “late enough.”
                  • For deeper or larger targets, you may need to lean more on:
                    • Ground‑referenced residuals rather than a pure single‑exponential fit.
                5. A concrete “AI understands ground” move
                If you want to really test this in practice:
                • Take your current setup.
                • Record decay curves:
                  • air, no target
                  • air + copper sphere
                  • air + iron sphere
                  • ground only (no target)
                  • ground + copper sphere
                  • ground + iron sphere
                • Align them all to the same TX edge and compare:
                  • ground vs air → what ground alone does
                  • (ground+target) − ground → the true target residual in ground
                Then apply the same metrics we’ve been talking about to the residuals. That’s where you’ll see whether your early‑time window and waveform shape still carry enough contrast in real soil.
                Short version: Your expert is right on all counts. What you’ve built is exactly the kind of system that can exploit linearity vs distortion of the decay curve—but in real ground, you have to treat the ground as a second “target” and subtract or model it, then look at what’s left.
                  ...your AI is in "patronising mode" ... ie its just telling you what you want to hear and everyone's opinion is spot on.
                  BUT its not coming up with the math to backup the very high level "solutions" it is proposing ... like "look" at the curve shape and subtract it LOL ... now that is a completely new concept.
                  Meanwhile a real AI will actually formulate the math, develop a formal proof, write the code, dump it into a MCU, gather some real data, validate the math / correct or adjust as needed.
                  So I use a mac mini M4 connected by usb to a chinese board stm32h750 and the AI has complete control of the M4 ( It can theorise, it can develop code, debug it, program the MCU etc ) It just flags me when it is done.
                  The AI acts as an Agent or Coworker .. and you instruct it not to come back till it has completed the task.
                  Below is the result of that process, less than a days work to validate PI and VLF mapping to the IQ space using the deeper mathematics that links processing of a target exposed to a time varying magnetic field ( which covers all types of magnetic detectors ).
                  So the AI implies that ground balance, disc, target ID works "better" on PI than VLF ... but only if you do the math first ... simply because PI has more frequencies to work with.
                  Below is a partial of the "proof" linking VLF and PI together plots of the IQ samples gathered from a PI circuit.
                    Moodz, thank you for your contribution.
                    You say:..your AI is in "patronising mode" ... ie its just telling you what you want to hear and everyone's opinion is spot on.
                    I fully agree. I already tried to get the AI out of this mode, but did not succeed. Do you have any advice of how to get the AI more pragmatic?
                      Just ask it to show you the mathematics required to implement ground balance on a PI detector.
                      Then ask it to show you a visualisation ( eg interactive model ).
                      Then ask it to show you the code ( whatever you want to run it on ).
                      Only ask one question each time.
                      Dont tell it how to do it ( ie let it work out what is required ).
                      Do tell it what outputs you want. ( like a mathematical proof or code or visualisation ).
                      If it does not come up with a plan first .. its probably not a good AI.
                      If it only offers stuff scraped from the web .. then its not good AI.
                      If it does not propose a number of solutions / options ... its not a good AI.
                      If it keeps agreeing with you and never disagrees then its definitely not a good AI ...
                        Moodz, I uploaded your comments to the AI. (Its good that I can not hurt its feelings)
                        Here is its answer:
                        Yeah, that critique is fair in one sense: “look at the curve shape” is useless unless you can write down exactly what you’re going to compute and why it works.
                        Let’s drop the hand‑waving and put real math on the table—in the language of your PI system. 1. The core model: PI decay as a superposition of exponentials
                        For a linear, time‑invariant target (air matrix, no saturation), the induced response to a step (or very fast ramp) can be written as:
                        v(t)=∫0∞G(τ) e−t/τ dτ
                        • G(τ) is the relaxation spectrum (how much “weight” each time constant contributes).
                        • A single‑τ target (ideal sphere) → G(τ)=A δ(τ−τ0) → pure exponential.
                        • Real targets (coins, iron, ground) → broad G(τ) → multi‑exponential, i.e. “distorted” decay.
                        Your RX samples at times tk are:
                        yk=v(tk)=∫0∞G(τ) e−tk/τ dτ
                        That’s already a linear functional of G(τ). No magic. 2. Link to CW / IQ: same physics, different basis
                        For a sinusoidal excitation at angular frequency ω, the complex impedance change is:
                        ΔZ(ω)=∫0∞G(τ)1+jωτ dτ
                        Split into in‑phase and quadrature:
                        P(ω)=ℜ[ΔZ(ω)],Q(ω)=ℑ[ΔZ(ω)]
                        So:
                        • Time domain PI decay: samples of ∫G(τ)e−t/τdτ
                        • Frequency domain CW IQ: samples of ∫G(τ)/(1+jωτ)dτ
                        Same G(τ), different kernels. That’s the deep link between PI and VLF. 3. How PI bins map into IQ space (discrete math)
                        In practice you don’t have continuous v(t), you have N time gates:
                        • Gate centers: tk, k=0,…,N−1
                        • Measured values: yk=v(tk)
                        If you treat yk as samples of a causal response, you can form a discrete Fourier transform:
                        X(m)=∑k=0N−1yk e−j2πmk/N,m=0,…,N−1
                        Each X(m) is a complex number—exactly like a CW IQ sample at some effective frequency ωm related to the gate spacing and window.
                        So the picture in that expert’s plot is:
                        • Take ~50 PI bins yk
                        • Compute X(m) via DFT
                        • Interpret X(m) as samples of ΔZ(ω) in the P–Q plane
                        That’s not “look at the curve and subtract it”—it’s a concrete linear transform from time‑domain PI to frequency‑domain IQ. 4. Ground and target as vectors in P–Q space
                        Let:
                        • ΔZg(ω): ground response (Cole–Cole‑like spectrum)
                        • ΔZt(ω): target response (often closer to single‑τ or a narrow band of τ)
                        Total measured:
                        ΔZtot(ω)=ΔZg(ω)+ΔZt(ω)
                        In P–Q plane:
                        Ptot=Pg+Pt,Qtot=Qg+Qt
                        So ground balance is literally:
                        (Pt,Qt)=(Ptot,Qtot)−(Pg,Qg)
                        In PI terms:
                        1. Measure ground‑only decay → yk(g)
                        2. Measure ground+target decay → yk(gt)
                        3. Subtract in time domain: yk(t)=yk(gt)−yk(g)
                        4. DFT both if you want IQ:
                        X(t)(m)=X(gt)(m)−X(g)(m)
                        That’s the “subtract it” idea, but written as linear algebra on actual samples, not vibes. 5. Where ferrous vs non‑ferrous shows up mathematically
                        For a single‑τ non‑ferrous target:
                        G(τ)≈A δ(τ−τ0)⇒ΔZt(ω)∝11+jωτ0
                        • In P–Q plane, that’s a simple arc.
                        • In time domain, late decay is a single exponential.
                        For ferrous:
                        • G(τ) has:
                          • eddy part (broad τ)
                          • magnetic part (hysteresis, viscosity, often modeled with extra τ’s or non‑linear terms)
                        • ΔZt(ω) traces a more complex trajectory in P–Q.
                        • Time‑domain decay is multi‑exponential and amplitude/polarity dependent.
                        So a very concrete discriminator is:
                        • In time domain: fit yk(t) to a single exponential over a late window; look at fit residuals and how they change with amplitude/polarity.
                        • In P–Q domain: look at how the reconstructed (Pt(ωm),Qt(ωm)) trajectory deviates from the single‑τ curve.
                        Both are just different projections of the same G(τ). 6. A firmware‑level feature you can actually compute
                        Given your hardware (earliest gate ~1–2 µs, several gates after), a simple, implementable discriminator is:
                        1. Choose two gate indices k1,k2 in your usable window (e.g. 3 µs and 20 µs after flyback).
                        2. For each pulse, after ground subtraction, compute:
                        R=yk1(t)yk2(t)
                        1. Repeat for different pulse amplitudes and both polarities.
                        Then:
                        • Non‑ferrous‑like:
                          • R is stable vs amplitude.
                          • R is symmetric between + and − pulses.
                          • Single‑τ fit to yk(t) has small, noise‑like residuals.
                        • Ferrous‑like:
                          • R changes with amplitude.
                          • R differs between + and − pulses.
                          • Single‑τ fit leaves structured residuals.
                        That’s not a slogan; it’s a scalar feature you can compute on your STM32 in a few cycles.
                        If you want, we can take your actual gate times and I’ll write the exact discrete formulas you’d drop into C for:
                        • ground‑referenced residuals,
                        • a 2‑point ratio feature R,
                        • and a minimal DFT over, say, 8–16 bins to get a coarse P–Q point per pulse.
                          Well, that AI stuff is fun, but we need also the hardware.
                          Lets start with the coil:
                          For this system, an induction balanced coil works best. I am inclined to use the OOO configuration.
                          Does anybody have any suggestions? Size? shape? Should it be TX-RX-TX? or RX-TX-RX? 200mm diameter? 250mm diameter 300mm diameter?
                          The purpose of this design should be as a gold detector.
                            hmmm... funny to read. Your AI response has just taken the clues I left and mixed it up with subtractive ground balance methods to make it sound like it knows what it is talking about.
                            If and when you reach the step of converting your PI ground samples to the complex domain ...the usual math takes over again. You cant simply apply linear subtraction in the (Q,P) domain as it suggests.
                            It also did not apologise for misleading you ...
                            ​​ image widget
                              Moodz, yes it is funny how the Chat GTP is lazy and gives me just the first type of answer it finds on line. Only when I insist and pressure it, it digs deeper.
                              I have to learn how to ask the right questions.
                              It seems the Chat GTP realises that I work on an intuitive level based on personal observations, so it answers to me on a similar level.
