Pulse Delay Pot and LED Placement
    You did cut the track and wind the on board trimmer to zero ?
    Thanks 6666, Yes sir, I did cut the space between the 2 holes for the added delay when I built it.. But I had read it wasn't needed
    with the new boards somewhere on here. As far as setting the trimmer to zero, I set it to detect at the best spot
    (which if I remember correctly it is at approx. 17k) and was told the added delay will act as a fine tune for whatever range it is set too.
    So basically, you are saying set the onboard trimmer to zero and use the outboard control for the delay. I guess that
    would just eliminate the need for the onboard trimmer all together sort of like what bernte mentioned above.
    I'm thinkin there is a real need to gather the info that is correct, the mods that work etc and put them together
    in a pdf and save it. There are so many different people saying to do this or do that yet, like yesterday,
    I came in to get the schematic and was told "xxxxxx is the best one" so I used it. Well, 5 minutes into the process
    I notice the schematic didn't even match the pcb image that came with it. The connection of the trimmer delay and
    pins on the 40106 as an example, were incorrect between the 2 docs...
    Anyway, Thanks for the heads up and I'll give your advice a whirl just to see what it does. Right now the detector is
    working fairly well with a slap together spider/basket coil so I may just leave it just the way it is.
      Did none of you think to look at the top of the Baracuda Project thread?
      Full construction details
        Hi Qiaozhi,
        Yep, I did.. the only problem I have is even with my glasses on I cant see the parts
        or numbers on the hand drawn schematic. If I try to zoom in on it, it just gets blurrier for me...
        Its no big deal, got it figured out now, just really wanted to see why the external delay
        pot I added wasn't working or doing anything.
        I was just doing a meter measurement and with the probes on the pot pins that
        are wired to the board, I get 0 reading no matter where the dial is turned. Probed the
        terminal that is not used on the pot and the #1 terminal and I get a 0 to 8.97k reading (10k pot)
        turning the dial.
          GC1
          have a look at these drawings one shows the timing cct you should be able to read the values just click the thumbnail to give full size picture
            Thanks 6666, man I searched all over for that earlier, I knew I'd seen those drawings somewhere in here and knew they had to be some where... Thanks man, that is a big help...
            Good gosh it sucks losing eye sight, I'm only 50 for cripe sake...... use to have 20/10 in both eyes...
