Originally posted by Andi68
Baracuda broken
With the scope I set the voltage exactly to 0V at Pin 6, Ne5534 and the sample delay with 16μs too small, VD 10 was broken.
And as I said, I was looking for the components, only today I tried a different setting without Scope
The circuit also works with C22 / 23- 470nF and C21-220nF
Replacement type for the 2N5485 = BF247
Now the world is alright for a short time
Would you mind telling what are your coil specifications thanks ?Originally posted by Andi68 View PostWith the scope I set the voltage exactly to 0V at Pin 6, Ne5534 and the sample delay with 16μs too small, VD 10 was broken.
These are rather test coils, so not yet valid.
Both coils are wound with copper wire 0.5mm, the number of turns I do not remember.
10cm, 1.3 ohms, 206μH
16cm, 1.5 = ohms, 295μH
For the small coil, I have the winding split into layers, it makes me a better impression than the 16cm coil.
