I finally got the circuit built and it seems to function as mentioned except for one small problem, the frontend is a little deaf compared to a standard mono front end.
I end up taking the blocking fet circuit out and used a matched pair of 1k resistors and crobar diodes on the TX fet side then into a diff amp. My modified setup works fine, the TX is about 100us running about 400volts flyback and it's decay at the diff amp is about 6us.
Mick
Mick
This will eliminate the flyback pulse having to travel up the coil cable to the control box ..
However it is via a two sample method
which is not quite as "neat" as the single sample used on the differential coil.
