Threshold Pot doesn't work
  • Carl-NC
    Originally posted by h9361 View Post
    Is C1 and R8 as High pass filter and C3 and R6 as low pass filter?
    Yes.
  • h9361
    I'll disagree, your results don't look right. Here is what I get:
    Your peak results are -29dB and it should be close to +40dB, and your highpass cutoff is too low at ~200Hz. Make sure you are using a wideband opamp (I use the NE5534) or an ideal opamp, and make sure it is properly powered.
    Thanks for information.
    Please see my schematic,
    I simulated it:
  • Carl-NC
  • h9361
    A simple hand calculation tells me that the circuit has a break frequency (Fb) of 3.39kHz, and a cutoff frequency (Fc) of 33.86kHz, so your simulation now looks correct.
    Thanks dear Qiaozhi.
    As you said, range is between 3.39K to 33.86K.
    See attached, i added a white box for this range.
    But i can not understand this. for exp, the 1.5K is out of the range, but i see it at the highest gain.
    Or, see 33.86 that is in the range, while it has low gain.
    I thought that we have high gain only for 3.3 to 33.8 Khz.
  • Qiaozhi
  • h9361
    I don't think you understood Qiaozhi's concern. You have an input amplitude of 2.5v and a gain of 100, therefore the output amplitude should be 250v. You will either need to power the opamp from +/- 250V or reduce the input amplitude to 50mv. I suggest reducing the input. Also, if you power the opamp from +12V/0V then you need to offset the input signal by 6V. Or you could power the opamp from +6V/-6V and then the input doesn't need an offset. Finally, if you want to see how the filtering looks over frequency you need to perform a swept AC analysis, not a transient analysis.
    These are all fundamental issues you need to understand if you want to have any chance of success. I suggest you spend more time learning these fundamentals. There are lots of video tutorials out there that will help with this.
    Thank you for your explanation.
    Edited power to +/-6 V.
    Amplitude to 50mV :
    AC_sweep Settings frequency range:
    Your band pass filter is from 3.3K to 33.8K.
    ​AC_sweep graph for V_out (Out of lm35) :
  • Carl-NC
  • h9361
    You have specified a 1V input amplitude in the simulation but the supply to the opamp is 5V.
    The opamp has a gain of 100, so that the output is hitting the power rails.
    Also, your opamp is a single supply type, and you haven't biased the input around 2.5V.
    Carl's example is designed to run from +/- supplies.
    Thanks.
    I changed supply to 12V and biased input frequency to 2.5V.
    Click image for larger version  Name:	schematic.jpg Views:	0 Size:	78.8 KB ID:	444907
    Click image for larger version  Name:	frequency.jpg Views:	0 Size:	48.9 KB ID:	444905
    1k frequency
    Click image for larger version  Name:	1K.jpg Views:	0 Size:	103.0 KB ID:	444906
    10K
    Click image for larger version  Name:	10k.jpg Views:	0 Size:	106.4 KB ID:	444908
    45K
    Click image for larger version  Name:	45k.jpg Views:	0 Size:	105.2 KB ID:	444909
    Both 1K and 45K is out of band pass range.
  • Qiaozhi
  • h9361
    I don't understand your schematic (bandpassmain.jpg) unless you are trying to build an energy-theft detector, or maybe PI. It is not what you would use for VLF. That's one of the problems with this thread, you have jumped around a lot of different topics so I often don't know what you are trying to do. It would have been better to use separate threads.
    Anyway, this is normally how I would make a VLF bandpass preamp:
    Click image for larger version  Name:	image.png Views:	0 Size:	27.9 KB ID:	444894​
    C1,R2 form the high-pass filter and C2,R3 are the low-pass filter. It would be a good exercise for you to put this in Spice and see how it works, and how to change the values to get the frequency range you want.
    I simulated your schematic.
    My settings for producing frequency is as follows:
    Click image for larger version  Name:	frequency.jpg Views:	0 Size:	51.6 KB ID:	444898
    And your schematic is :
    Click image for larger version  Name:	schematic.jpg Views:	0 Size:	102.2 KB ID:	444902
    output of LM358 for 1K input frequency:
    Click image for larger version  Name:	1K.jpg Views:	0 Size:	108.1 KB ID:	444899
    Output for 10K :
    Click image for larger version  Name:	10k.jpg Views:	0 Size:	106.7 KB ID:	444900
    And output for 50K:
    Click image for larger version  Name:	45k.jpg Views:	0 Size:	109.9 KB ID:	444901
    I thought I have no output if I produce a frequency out of this range.
    1K and 50K is out of this band pass filter but i have still output!
  • h9361
    Thanks for your helping.
    Is RX inductor with R1 considered as RL high pass filter?
  • Carl-NC
  • h9361
    There is no "better" either way, you do what is needed to get the results you want.
    Dear Carl
    Please see it, i think your mean is like it. There are both highpass and lowpass filters in before and after:
    Now please see following: it is my preamp. I think i should add a high pass filter before it. But i think it has a filter after it, C2, R6 and R7.
    Is the 10u (c2) and 10.4K (R6+R7) high pass filter?
    If yes, so i should change it as low pass filter for making my interested band pass filter.
  • h9361
    Thanks.
  • h9361
    All multifrequency designs I am aware of use a wideband RX coil and either do narrowband filtering in the preamp(s), or with filters after the preamp, or use narrowband demodulators. I don't know of anyone trying to use narrowband RX coils.
    So, i think it is better to use a wideband RX and to add a narrowband filtering in preamp.
    Please see attached, the out of transistor preamp goes to LM358.
    Can you tell me which point i should put the filter?
    Please see C2, R6 and R, are they filter?
