Threshold Pot doesn't work
  • h9361
    Maybe you should measure the TX pulse width and frequency of the Lorenz. Often these large-coil detectors run a very wide pulse width at low frequency for detecting large deep targets.
    That should work.
    That should also work.
    It depends on the micro and also how you intend to create the pulses. Are you going to bit-bang them or use PWMs? There are a lot of ways to do this.
    Thank you for your supporting, dear Carl.
    My method for micro is based on PWM.
  • Carl-NC
    Originally posted by h9361 View Post
    As you know, lorenz delay will be increased more than 70us if we fold frame to 150cm. But lorenz is detecting the shovel from higher depth with the higher delay, while i can not reach this depth with lower delay!
    Do you have any suggestion for changing my hhd?
    Do you think i can reach via following switch without removing R25 ( because i can not more edit on PCB)?
    That should work.
    One a method on pcb is, remove one pine of R27, c18 and R25. Then, connect them ( the opened pins) together in air.
    See attached, do you have better solution?
    But there is a big question. Please see your HHD schematic, i want to put both single and double sampling.
    Can you guide me what output from micro (N4) can acts single sampling?
    Other words, what output from micro can connect pin3 of IC8 to ground?
  • h9361
    Ideally high inductance gives you more "transformer gain" but practically there is not much difference.
    Dear Carl
    Please accept my apology for more questions.
    I am going to make my HHD ( without GB, the your original schematic) with micro.
    So, my micro will generate Frequency and two sampling pulses.
  • GeoMax
    Hi h9361
    Thanks for the explanation. I didn't realize the depth difference was so significant with large coils and single sampling. Now I understand why guys from the Middle East and North Africa always rave about the PI Polones and say it "goes deep". The PI Polones is also a single-sample detector.
  • h9361
    Hi H9361,
    what is the benefit to choose between single and double sampling?
    Hi dear GeoMax
    The single sampling is a simple pi.
    This is not good for using coil, it is good only for using big frame.
    At least, 150 x 150 cm or bigger.
    Since the frame is big, so it will not detect any small objects or it has very low sensitivity to minerization. So it is a bit stable and does not need EFE sampling.
    But its benefit is reaching to a very very high depth for bigger object.
    I want to add this mode to my HHD for using on special point.
    For exp, i tested lorenz z2, it has two modes: 1- single sampling 2- two sampling
    In two sampling, it exactly detect objects like HHD depth.
    But its single sampling mode detects very higher depth.
    For exp, i tested iron shovel with the two modes:
    Single sampling: 370cm depth
    Two sampling : 200-230 cm
    I think we can use this mode in some ground.
  • GeoMax
    Hi H9361,
  • h9361
    Please see, we have a limitation for adding switch between single/double sampling on pcb.
    Click image for larger version  Name:	single.jpg Views:	0 Size:	118.8 KB ID:	445018
  • h9361
    I study Lorenz z2 user manual, i understand that he put both single and double samplings.
    The option DEL is simple one sampling and the option GND is two samplings (Target + EFE).
    Dear Carl, i read your HHD articles, you mentioned that we can reach to one single sampling via removing R25 and C18 and R27, then connect pin2 of IC8 to ground.
    I want to add a simple switch for single/double sampling on my HHD PCB.
    Click image for larger version  Name:	OneSampling2.jpg Views:	0 Size:	35.1 KB ID:	445008
  • h9361
    Thank you.
    Dear carl i have a guestion about you HHD.
    I adjusted follwing settings:
    Delay 10-12 us
    EFE delay at its maximum, near 300us
    Sample width 20us
    Frequency 1000pps
    TX 100us
    Threshold is its lower pit ..pit
    I also made a big coil 125cm x 125cm using SFTP Cat 5, 500uH.
    I tested this coil as fixed on ground with Iron shovel, my depth was 200 to 230cm, not more.
    Again i made another bigger coil using cat 5, 150x150cm.
    My depth is increased 10cm, not more.
    Similarly, i bring a lorenz z2 with 3m frame but i fold it so that its size converted to 150x150 ( this has been said in its user manual).
    I tested it with Iron shovel at fixed coil, depth 370 cm!
    There is a big question, why i can not reach to this test!
    I thought my audio part had lower sensitivity.
    So I increased gain of audio part R29 from 100k to 220k, but no result.
    I think problem may be in threshold process.
  • Carl-NC
  • h9361
    10k. But why is your RX coil only 2uH?
    I wrote wrong, 200uH is correct.
    Before, i had experienced only RX (200 uH) without TX , i could detect old metals.
    Generally, i have a question.
    please consider following:
    500uH+5n = 100Khz
    5mH+500p= 100Khz
    Which of them is better? higher or lower inductance?!
  • Carl-NC
  • h9361
    Practically, they don't affect the signal. Some detectors leave out R1, I prefer to include it to dampen potential oscillations.
    thanks.
    Do you have a suggestion about R1 for 10khz to 120khz?
    My RX is 2uH.
  • Carl-NC
  • h9361
    I don't understand your schematic (bandpassmain.jpg) unless you are trying to build an energy-theft detector, or maybe PI. It is not what you would use for VLF. That's one of the problems with this thread, you have jumped around a lot of different topics so I often don't know what you are trying to do. It would have been better to use separate threads.
    Anyway, this is normally how I would make a VLF bandpass preamp:
    C1,R2 form the high-pass filter and C2,R3 are the low-pass filter. It would be a good exercise for you to put this in Spice and see how it works, and how to change the values to get the frequency range you want.
    Please forgive me.
    About RX and R1, are they considered as high pass filter (LR)?
