Threshold Pot doesn't work
  • eduardo1979
    Hi h9361.
    Why don't you try implementing the TX circuit from the Fisher CZ5? I think it would be a good starting point.
  • Carl-NC
    Originally posted by h9361 View Post
    Please check attached. Do you think the bandpass (from 15Khz to 107Khz) is true?
    Again, I don't know without simulating it. It will also make a difference whether L3 and L4 are coupled (also polarity) or decoupled.
  • h9361
    Originally posted by nejdet View Post
    Something like this maybe...
    thanks
  • h9361
    here is a free online tool for desiging LC filters ( low, band, high )
    https://markimicrowave.com/technical...r-design-tool/
    It can export the design in ltspice so you can sim it.
  • h9361
    I suspect it's not so simple, and I don't know without either building the circuit or simulating it. But you can do that, so I suggest you put it in LTSpice and find out what happens.
  • nejdet
  • moodz
  • h9361
    I have not worked with LTSpice. I usually use Porteous software for simulation, i will try to simulate it.
    I have a another question. Please see again schematic of #618, do you have any suggestion for making a bandpass filter?
    For exp, i want to only receive from 5Khz to 30Khz range. Suppose that we have two coils ( inductor) and two resonance capacitors.
    First Tank is tuned to 5Khz and second is tuned to 30Khz. But i do not know how to draw a bandpass for this range via this coils and resonance capacitors.
  • Carl-NC
  • h9361
    Any coil can do that as long as you don't resonate it with a cap.
    I want to receive only two or three frequencies at the same time.
    Please see attached, this is named as coupling mode (Tap).
    Click image for larger version  Name:	resonance.jpg Views:	0 Size:	44.0 KB ID:	444848
    A friend told me old radio used this method.
    I have a question, which of the following is true?
    Calculation 1
    F1=(L1+L2+L3)+C1
    F2=(L1+L2)+C2
    F3=L1+C3
    Or
    Calculation 2
    F1=(L1+L2+L3)+C1
    F2=(L2+L3)+C2
    F3=L3+C3​​
  • Carl-NC
  • h9361
    Are you wanting an RX coil that can receive 2 frequencies, or a TX coil that can generate 2 frequencies? What you show cannot oscillate, it has no feedback mechanism. Otherwise, I have no experience trying to do what I think you want to do.
    Only receiving RX without any TX.
  • Carl-NC
    This model can receive two frequencies Simultaneously.
    Is it possible to tell me your opinion?
  • h9361
    what are the frequencies ?
    KHz range,
    exp, 30 and 70Khz.
  • pito
