Originally posted by h9361
Threshold Pot doesn't work
HelloOriginally posted by Carl-NC View PostIn most cases, no.
Dear Carl
Please forgive me for my question.
Is it possible to help me about the following problem (attached pic)?
I want to connect pin7 to ground if its below schematic has output (uV output).
The blue box is a simple method but i don't know its resistor values and connection point of the below schematic (red line) is true for active/deactive the bc847?!
I hope you accept to guide me, thank you.
Dear Carl
I hope you are passing good days.
As you know, i am using the audio schematic (#339 post in this thread) for my HHD.
In addition, i added a DISC schematic for Fe detection (you can see its end part, output) and it works but its output is uV.
Now, i want to connect my DISC output to the audio schematic so that my audio generates a silent or cut off sound if the DISC pcb have an output.
Is is possible to guide me which points are better to be connected together?
Thank you.
Thank you for your valuable information.Originally posted by Carl-NC View PostThe RX coil is usually connected to a high impedance preamp so the RX coil current is very low and thinner wire can be used with no reduction in sensitivity.
So there is no difference between thinner and thicker wire (RX) for sensitivity.
- Likes 1
You can get RG59 with a stranded center conductor.
Dear Carl
I have a question about DD coil.
As you know, commercial coils use thicker wire for TX and thinner wire as RX.
My question is about thickness of RX wire.
Do you think thickness of the wire (RX) affects on sensitivity of PI machine?
Dear CarlOriginally posted by Carl-NC View Post
I am going to design SMD PCB for my HHD+GB.
As you know, for adjusting offset of 5534, i must not to install IC 8 (TL072) and connect its pin1 to ground.
Anyway, do you have any suggestion for this problem so that i can adjust the offset with installing IC8?
Thank you
Originally posted by pito View PostDo you have any suggestion (cable) for DD coil? = that was your question, DD has 2 coils so the best is to use two separate shielded pairs.
but it destroys TP4 form = show circuit
Thank you my friend.Originally posted by pito View Post
I already used the Audio cable, but it destroys TP4 form if i use a shield to coil and connect it to ground!
Soundco microphone cable model 3030 has two stereo cores with 28 copper strands, coated with polyethylene insulation in two colors, white and red. 64 all-copper shield strands spun around two core strands, with a copper foil and silk and thread strands, for high strength and no wire breakage even in harsh conditions and under pressure, handle covered with soft and flexible PVC outer insulation is.
