Threshold Pot doesn't work
  • Carl-NC
    Originally posted by h9361 View Post
    I checked its last path (IC8b-pin5), no noise and it is clear.
    IC8 has a gain of 100 so you will need to increase the oscope sensitivity to 50mV/div to get an equivalent measurement. Did you do that? I suspect you will see the same problem and that it is just a normal integrator waveform. This means you either have too much gain in IC8 or not a high enough integration tau.
  • h9361
    If you probe the signals at CH1 and CH2 are they noisy? Be sure to increase the o ​scope sensitivity to compensate for the gain of IC10.
    Circuits generate their own noise and I have no idea where your noise might be coming from. You will need to probe the circuitry, including the power supplies, to figure it out. Noise is more sensitive in the preamp because it sees the most gain through the whole signal path. Also, it would help if you posted a real schematic instead of a block diagram.
    Thank you dear Carl for your guidance.
    I checked all voltage +5/-5 on scope, it is clear without any noise.
    After a lot of trying, i could find my noise path.
    First, please see my schematic (attached).
    I have a noise (incorrect signal form) only in IC8b-pin7 (my main channel).
    I also checked IC9b-pin7, no noise. If you see in scope, it is pulse form, it is because of my gain pot.I increased it in last position, maximum gain. If i decrease the gain, it will be a clear line, no pulse. In my scope, channel 1 is IC9-pin7, channel 2 is IC8b-pin7.
    I think gain of IC8b is high, do you think i should decrease R53 value?
    (for better understanding, i show my noise path with blue line)
    I measured all result without connecting coil.
    Thank you
    Click image for larger version  Name:	schematic2.jpg Views:	0 Size:	181.4 KB ID:	414480
    Click image for larger version  Name:	twoR57-58-2.jpg Views:	0 Size:	118.2 KB ID:	414479
  • Carl-NC
    If you probe the signals at CH1 and CH2 are they noisy? Be sure to increase the oscope sensitivity to compensate for the gain of IC10.
  • h9361
    Yes.
    Hello dear Carl
    Before everything, thank you for your guiding (changing non-motion to motion).
    According to your advise, i added your suggestion part to my PCB and it works motion.
    But i have still a problem and i can not solve it.
    For better understanding, first see attached pic.
    I connected my O-scope to last opamp output (final subtraction, red point ) and captured a short video over O-scop from ( link attached).
    As you see in video (o-scop), i have not a clear DC output and it fluctuates. So, my audio also will show the fluctuation voltage as shaky voice.
    (my audio schematic is at #339)
    What is interesting is that i have still such fluctuation output even without connecting coil! I also screw GB pot but still it is not clear dc (without connecting coil).
    you can download my video from the link
    https://www.mediafire.com/file/k2dy9...04509.mp4/file
    Do you have any idea to solve the problem?
  • h9361
    Yes.
    Thank you.
  • Carl-NC
    Yes.
  • h9361
    Yes, that's the way I would do it. Here is a (very) simplified diagram:
    It is important to closely match the delays through the integrators and the SAT stages.
    Thank you dear Carl for your helping.
    See attached, is the position true (red points)?
  • Carl-NC
    I already added SAT at final out, no result.
    Do you think i should add two SAT at CH1 and CH2, before subtracting and gain ?
  • h9361
  • h9361
    This most likely due to thermal noise generated within the circuitry. Probably CH2 is worse because it typically runs at a higher gain. You can't get rid of all the thermal noise but you may be able to improve it. That requires knowledge of noise analysis. Search the forum, there have been discussions on this.
    Hello
    dear Carl
    Please forgive me for my questions.
    As you know, i added GB (based on 4 sampling) to HHD (attached). Now, my HHD works as non-motion mode so that it produces a constant audio (noisy audio) if i keep a target near the coil.
    Do you have any suggestion for changing my HHD to motion mode? I also added its SAT part but it had no result.
  • Carl-NC
  • h9361
    The TDI has a pulse width of 100us but it also burns 6 watts of power and has heat sinks. A wider pulse width helps more with high-tau targets than low-tau targets.
    Hello
    Dear Carl
    Please forgive me for my more questions, i hope you forgive me.
    Time that the question has engaged my mind. Please first see attached, it's my two channels for GB processing. In fact, we use the GB pot (in ch2) for reaching zero volt at final output.
    The my question is here! I don't connect any coil to my PI, so we must have a static dc voltage at output. But i have a voltage fluctuation output in without using coil!. For example, 2.741-2.750 V.
    This fluctuation will show at audio sound and unfortunately i have not a stable audio in basic mode. Do you have any suggestion for solving such problem (for stabilizing audio)?
    Thanks for your kindness.
  • h9361
    Dear Carl
    Thank you for your guiding.
    Today i tested my HDD, now it detects foil of smoke box 60cm.
    My settings is as follows,
    Freq. = 2.6 kHz
    Sample width = 25 uS
    TX pulse = 100 uS
    Delay = 6-7 uS
  • h9361
    Thank you dear Carl.
    Today, i read user manual of the Axiom (new PI machine) from Garret company.
    What caught my attention is the frequency of 1500 Hz!
    ​The detector can detect low tau target with the frequency.
  • Carl-NC
