Threshold Pot doesn't work
  • h9361
    As you know, i built HHD with GB.
    But HHD has a low sensitivity to nugget and thin foil.
    First, i want to increase frequency for fast responding.
    Second, set delay time to 8us.
    Third, change 5534 by GPX amp.
    Maybe i can increase its sensitivity to thin foil.
  • Carl-NC
    You can run the pulse rate higher but you need to pay attention to heat dissipation. Usually a higher pulse rate requires a shorter TX pulse. You also need to pay attention to timing constraints, especially with the EFE pulse spacing.
    What are you trying to accomplish?
  • h9361
    Hello
    Dear Carl.
    I hope you are passing good days.
    Please forgive me for my questions.
    I want to increase TX frequency of HHD to 4-5KHz.
    Do you think HHD can work over the range or i must use it over its maximum original range 900-2300Hz?
    Thanks.
  • h9361
    Hello
    Dear Qiaozhi
    I measured DD ML coil inductance (GPX series)
    TX: 296 uH
    RX: 880 uH
    Do you think the values, especially RX value, good for Voodoo project?
    Thanks.
  • h9361
    Thank you.
  • Carl-NC
    Yes
  • h9361
    The top 7805 should connect directly to the other 7805 (no diodes). You should also check your power budget to make sure the 7660 can supply the additional current.
    Thanks.
    Is that correct?
  • Carl-NC
  • h9361
    Hello
    Dear Carl
    I'm going to develop HHD by adding some ICs.
    I think power of HHD may can not generate adequate current.
    So, i want to generate a separate +-/5V for the ICs.
    Please see attached, do you think it's correct?
  • Qiaozhi
    Originally posted by h9361 View Post
    IRAN.
    Try this ->
  • h9361
    IRAN.
  • Qiaozhi
    An image of the waveform will not help you. Your approach of attempting to add ferrous/non-ferrous discrimination to and HH+GB combination is basically flawed.
    In which country do you live?
  • h9361
    Dear Qiaozhi
    I have no problem for buying the book.
    For exp, i already bought your IMD (second version, PDF version) and read !!!
    Unfortunately, my country is under boycott and your link (world wide web Book) will not send to my country!
    There is no Amazon or etc. office in my country!
    For this reason, i requested to buy its electronic version. So you again told me "no PDF"!
    Thus, i have to request you to only share me the wave form, and you told me again "No".
    Anyway, thank you for your replying and helping.
  • Qiaozhi
    I want to add only its DISC part. I don't want to reject Iron, just want to show it via a simple LED.
    Do you think it works?
    [ATTACH]57569[/ATTACH]
    The blunt answer to your question is "no".
    May I make a suggestion? ... Instead of phishing for information, why not buy the book and read it, and preferably build the Voodoo circuit.
    You will then understand why adding true ferrous/non-ferrous discrimination to a PI is not as simple as you think.
    As Carl has already said:
    If you have not successfully built the Voodoo circuit as it is designed then trying to convert HH+GB into a Voodoo-like hybrid will be exceptionally difficult. Build Voodoo first, get it working, and learn how it works.
  • h9361
    There is no ebook version of The Voodoo Project.
    Dear George
    I have a request, i hope you accept it.
    Is it possible to share me wave form at TP17 (DISC_OUT)?
    Thanks.
