Replies to Minipulse Plus
  • Please give alternatives to the Mur460 diode
    Also alternatives to Lt1054
    • I often use the STTH1L06.
      Options for the charge pump:
      ICL7660A (up to 12V)
      ICL7662 (20V)
      MAX1822 (16V)
      LTC1044 (12V)
      LTC1144 (18V)
      You'll need to check data sheets to ensure suitability.
      • Thanks
        • I have this available, is it enough?
          ICL7660 up 10v
          • Originally posted by Ssqqar12 View Post
            ICL7660 up 10v
            Only if you don't exceed 10V.
              I mean, there is no problem if you use it
              • If you don't exceed 10V, then there is no problem. If you exceed 10V, you will damage the part. What battery do you intend to use on the Minipulse?
                  12v
                  • If you apply 12v to the ICL7660 you will likely burn it up.
