Couldn't help my self waiting for components so I attached one of my 3dss coil...Just magical!!!Without setting the sensitivity trimmer the soda can is detected near 1m...Interesting though the particular coil that damped at 1.6k with the MPP with the CB it damped very nice and smooth at 560 Ohms with voltage near 440 volts..The preamp out is very clear so I'm thinking I have something faulty with my MPP pcb,I will have to look into the mur the mosfets and the preamp circuitry.I must notice that the CB has way more stable pulsing than the mine MPP..Difficulty is the pcb is both sides soldered and have small traces,take the parts out will need to be very careful,I wish I had another clear board...Never the less the CB seems to work very nice (even with 1 stage preamp)I adjusted the tx pulse at 150us and first sample at 10us(I can go lower).The frequency at 1000pps as advised,I wonder what is the sensitivity trimpot and how we should calibrate it.Also some directions I have at TP3 we calibrate for zero voltage at pr amp out,that done before the hole circuit is soldered,should I calibrate it again with the detector working?
I need your thoughts about damping guys especially George's advice since he is the designer..,what could be wrong with the MPP ...I'm thinking change the mosfets with a new one,the MUR diode and the 7555 pulse generator and the 5532.
