Let's make a closely MXT like detector!
  • Analysis of Selected White's MXT Firmware Subsystems
    Based on Reverse-Engineered Pseudocode
    Part 3: VDI and Target Classification
    Introduction
    The Visual Discrimination Indicator (VDI) is one of the defining features of modern VLF metal detectors. Rather than presenting raw signal information to the operator, the detector attempts to estimate the electrical characteristics of a target and map those characteristics onto a numerical scale.
    For many users, the VDI appears to be a simple target identification number. Internally, however, the process is considerably more complex.
    Analysis of the White's MXT firmware reveals that VDI generation is not performed from instantaneous signal measurements. Instead, the detector evaluates signal stability, tracks phase relationships over time, captures peak-response events, and only then updates the displayed target classification.
    This article examines the architecture of the MXT target identification system and the mechanisms used to transform detector responses into VDI values.
    Fundamental Principle
    A VLF detector transmits an alternating magnetic field and measures the phase and amplitude of the resulting receive signal.
    Different target materials produce different phase responses:
    Ferrous Objects
    Negative Phase Shift
    Small Gold
    Slight Positive Phase Shift
    Coins and Conductive Targets
    Larger Positive Phase Shift
    The purpose of the VDI system is to convert these phase characteristics into a repeatable numerical representation.
    In theory, the process appears straightforward:
    Phase Measurement
    Target ID Number
    The MXT firmware demonstrates that the practical implementation is significantly more sophisticated.
    Separation Between Detection and Classification
    One of the most important observations is that the MXT separates target detection from target classification.
    The detector first determines whether a signal event is valid.
    Only after signal quality requirements have been satisfied does the firmware attempt to calculate a target identification value.
    Conceptually:
    Target Detection
    Signal Validation
    This architecture reduces the influence of noise and unstable responses on displayed VDI values.
    Signal Stability Evaluation
    The firmware continuously evaluates the relationship between multiple filtered signal channels.
    Rather than using a single sample, the detector observes signal behavior over time.
    The system monitors:
    • Signal polarity.
    • Relative phase behavior.
    • Comparator transitions.
    • Signal persistence.
    • Peak magnitude.
    These measurements collectively determine whether a signal should be considered suitable for classification.
    Peak Response Acquisition
    The MXT does not classify targets from arbitrary signal samples.
    Instead, the firmware attempts to identify the strongest and most stable portion of the target response.
    Conceptually:
    Target Pass
    Peak Detection
    Snapshot Capture
    Classification
    During a sweep, the detector captures signal values near the point of maximum response.
    This approach improves classification consistency because measurements are performed when the signal-to-noise ratio is highest.
    Snapshot-Based Processing
    A notable feature of the MXT architecture is the use of internal snapshots.
    Rather than continuously updating classification variables, the detector stores selected signal states when specific conditions are satisfied.
    These snapshots preserve:
    • Signal magnitude.
    • Relative channel information.
    • Internal filter states.
    • Timing relationships.
    Once captured, the stored values are used as the basis for subsequent calculations.
    This design reduces sensitivity to short-term fluctuations and unstable target responses.
    Phase Estimation
    After a valid signal event has been identified, the detector estimates the phase relationship associated with the target.
    Although the exact implementation varies between detector designs, the objective remains the same:
    Receive Signal
    Phase Estimation
    Target Conductivity Representation
    The resulting value forms the foundation of the VDI calculation.
    The firmware evidence suggests that the MXT performs this process only after signal stability criteria have been met.
    VDI Scaling
    The calculated phase information is transformed into the detector's numerical identification scale.
    Conceptually:
    Phase Estimate
    Scaling Function
    VDI Value
    The scaling process allows targets with similar electrical characteristics to produce similar identification numbers.
    This provides the operator with a practical method of distinguishing between common target categories.
    Once a VDI value has been generated, the detector can perform classification and discrimination operations.
    Typical classification regions include:
    Iron
    Foil
    Small Gold
    Nickel Range
    Pull Tabs
    Coins
    High Conductors
    The precise boundaries are determined by firmware tables and discrimination settings.
    The classification stage converts continuous phase information into discrete target categories useful to the operator.
    Relationship to Discrimination
    VDI and discrimination are closely related but perform different functions.
    VDI attempts to estimate target characteristics.
    Discrimination determines whether those characteristics should be accepted or rejected.
    Conceptually:
    Target Signal
    VDI Calculation
    Discrimination Decision
    Accepted / Rejected
    This separation allows the detector to maintain a consistent target identification system while providing adjustable rejection behavior.
    Design Philosophy
    The MXT target identification system reflects a broader design philosophy visible throughout the firmware.
    Rather than relying on instantaneous measurements, the detector emphasizes:
    • Observation over time.
    • Stability verification.
    • Event detection.
    • Peak capture.
    • State preservation.
    The objective is not simply to calculate a VDI value as quickly as possible, but to calculate it only when the detector has sufficient confidence in the measurement.
    This philosophy prioritizes identification reliability over response speed.
    Engineering Assessment
    The analysis suggests that the MXT target identification system is built around signal validation rather than direct measurement.
    Many modern explanations describe VDI as a simple representation of target phase. While technically true, the firmware demonstrates that a significant amount of processing occurs before phase information is accepted as valid.
    The detector continuously evaluates signal quality, waits for stable responses, captures peak events, and only then performs classification.
    This architecture helps explain the reputation of the MXT for producing stable and repeatable target identification under difficult field conditions.
    Conclusions
    The White's MXT does not generate target identification values directly from instantaneous signal measurements.
    Instead, the detector employs a multi-stage acquisition process involving signal validation, peak-response capture, phase estimation, and classification.
    The resulting VDI system represents a carefully controlled decision process rather than a simple numerical conversion of phase data.
    This design reflects the broader engineering philosophy observed throughout the firmware: use simple computational building blocks, but combine them through carefully designed state logic to achieve robust real-world performance.
    Next Article
    Part 4: Discrimination Logic and Target Acceptance
    The next article will investigate how the MXT uses VDI information to accept or reject targets, how discrimination thresholds are implemented, and how the detector balances target recovery speed against classification accuracy.
    • شكرا لك KRinAZ
      • هل هاذي هيا انسخه. المحدثه v2.40.hex
        • Originally posted by Fadel saleh View Post
          Please make all posts in English.
            شكرا لك KRinAZ
            Hello, this appears to be Arabic?
            I don't speak Arabic so don't know what this says. Google Translate didn't work so well...
            As Carl said we need to post in English.
            • Originally posted by KRinAZ View Post
              Google AI can do it:
              "Is this the updated version?"​
                Hmmm, OK, well I suppose I don't know - since I don't know anything about a file named v2.40.hex, what it is, where it came from, what it is supposed to contain. Perhaps I missed the post where it was previously discussed, if it was...
                  So, from my little corner in Dante's hell (right moodz? ) here's what I think - going forward:
                  I know everyone really wants to not use a PIC micro, myself included (but only just), but there is one argument to be made for initially deploying a PIC16F76 - and that is because C code for the PIC16F is the closest / easier to produce C code (inspired by our disassembled code) that could be compiled and run in a MXT board - again I said initially, to test and verify we have good tested C code. If C code were produced that would compile and run in a MXT just as the original - then we would have a fully functional code base, tested, and ready to port to a STM32. My understanding is we currently do not have that yet.
                  The code is obviously both; where most of the operational magic is, and hard to produce even with the aid of AI. From where we are now - it seems to me to be easier to create code for a PIC16F than for the STM32 - as currently we have no way to test the code for a STM32 in actual hardware. Then as soon as that (C code for PIC16F) is accomplished the focus moves to; adapting the code base to run in the STM32, and producing the STM32 based version of a MXT board.
                  I have a number of things going on currently, so maybe I'm not moving so fast - but still I am currently chipping away at; producing a schematic of a STM32 based version of the MXT schematic, and understanding the specific differences between PIC16C and PIC16F in order to modify the disassembled PIC16C code to run in a PIC16F.
                  So what I propose as next steps:
                  1) Produce functional equivalent C code to compile and run - in a PIC16F76 - on a MXT board.
                  2) Test said code in MXT board and work out any bugs
                  3) Produce a STM32 centered schematic and pcb of the MXT
                  4) Have tons of eyes on said schematic and pcb to spot any flaws
                  5) Send the consensus approved gerber off to produce several pcb's
                  6) Port the PIC16F C code to the STM32
                  6) Have several folks run our pcb with our code in actual (modified for our use, more on that soon) MXT bodies and field test
                  7) Debug as needed
                  And enough with the copyright stuff, personally I don't give a hoot...let's move forward...onward thru the fog...
                  Thoughts? Disagreements? Agreements?
                  Hello KRinAZ
                  I will be one of those people.
