Originally posted by ripsdevala
TGSL prints
Thank's Ivconic, i also looked many times tgsl thread, but i didn't found cz5 files, only lay file has there.Originally posted by ivconic View PostAt the time i had spare enclosures from Fisher CZ5 and Fisher 1265 metal detectors.
So i tried to draw TGSL pcbs to fit into those enclosures, therefore i named my draws like that; "CZ5 and 1265".
At the time i also was not very skilled with Sprint Layout (not saying that i am now), so my pcbs are not state of the art.
Both are made and working.
If there are some differences; than those are "chronological" differences, as i experimented much with various modifications.
Each one of those should work.
I don't remember the details, but luckily i used to wrote about those in TGSL topic. I guess everything is there.
Btw, long time ago i maked your 1265 version, it is deeper for sure than version 3.0 with BD140 audio amp.
For LM308, UA741 or LM741 works perfect. For LF353 i found LM833 working much better, cause is low noise.Originally posted by ripsdevala View PostCan i change LM308 with OP07 or equivalent?
Got it by search, by mr ivconic him self
LM308~TL081
LF353~TL082
J107~BF245
Also, NJM2068 works too for LF353 replacement, but geb trimmer must be in another position to reject ferite and hot rock.
Should be:
LM308 = UA741, LM741, TL061, TL071, TL081,
LF353 = LM833, NJM2068, TL062, TL72, TL082
Thank for the reply CDI, I have lots of option now, LM308 its very rare and expensive here, i just found that TL071, TL072, TL082 is working to, i have pair each of them, the last problem is pots wiring, Im not sure with my sketch above and pic from net i just got.Originally posted by CDI View PostFor LM308, UA741 or LM741 works perfect. For LF353 i found LM833 working much better, cause is low noise.
Should be:
I will go to electro market now to get the missing parts.
Best,
Rips
9V adapter? Are u kiding me? u need minimum 11 volts to power unit. Use 2 batteries 9V in series to get 18v or some aku 12v. Using adapters or similiar thing which is powered with 220v is bad idea.Originally posted by ripsdevala View Post
