Originally posted by CDI
TGSL prints
Well done! But 12 V would be ok, you not need more!Originally posted by ripsdevala View PostAlready made perfect a pair with Rx 6.52 and Tx 6.02 after remove the nails, more stable without a lots beeping,.
Btw how to test my DMM if the 200Mv AC is working? Its make different result when nulling not like before. I make contact to 15v batt yesterday, im afraid i broke it.
Better with two channel, you will waste time and money, when you buy one channel oscilloscope. You need to adjust the proper phase TX RX. And the relationship between GEB and DISC. Take a look at Don's instruction, you will get all answers you need!
Today I have made and uploaded my first video of my TGSL.
Sorry, but I have no experiences with video making, not easy for me
to film and act at the same time, its my first try.
I have made the pcb in 2011, but I had one problem, with short distance, as I said before.
So the project was unfinished in my ,,unfinished projects box''.
Some weeks ago, after I finished my Krot2, I was able and happy to found my mistake. It was a missing resistor, 1k R27
and a bad choice of IC U106. I'm realy glad to found the fault, this days I build a compact box from ABS plastic sheet 1 mm.
The front is drilled and I want assembled all together with new VDI, for test purposes, I have tested the VDI from my IDX.
I'm very curious to see, how the detector will be working in the field...
