Problems with fresh built TGSL
I can't make two layer pcb so i choose apberg design. If you know a authentic and successful single layer design and parts list of tgsl then let me know so that i can make it according to your recommendation. Also i want a most a authentic single layer design and latest parts list of king cobra because i want to make it again.
Originally posted by kt315 View Postyou must do own design. your problem you take aliens' layout thinking all around you are just perfect.
do you see i took apberg lay or lay of anybody doing bara? doing king cobra?
yes, i took bulgarian lay for DP but if you can see i radically changed it.
you seems the generator of new threads bearing the noise. nothing new.
you do not able to do simplest schematic. iwgonik deleted all metal part from the tesoro
to do it more simplier. so it is compadre or amigo schematic in reality.
but you can not anyway. you even do not grasp what is tuning of coil balance. nobody still did not give
full detailed manual how to right tune. and you anyway take to do VLF.
Discrimination not working.
this schematic works ONLY in disc mode. if you get reaction thats disc is.
big problem i do not follow all threads! i do not have so much time!
http://www.md4u.ru/viewtopic.php?f=25&t=2681&start=350
look yourself -- 112 pages to read!!
if i will start one sided pcb it will be like nautilus revisited.
i must do a pcb for this enclosure! -- https://www.aliexpress.com/item/Alum...27f64924EOC88U
Give me a username and password in english language for this site
Originally posted by kt315 View Postbig problem i do not follow all threads! i do not have so much time!
Read TGSL thread, everything is already explained there many times. Only because you are lazy, you expect we will explain it again and again in another new thread about exactly the same topic?Originally posted by chuubaba View PostYou are complaining as if this thread is written on your nostrils
