The attached .pdf shows a preliminary detailed overview of a stand alone circuit board that will greatly aid those conducting experiments in PI metal detection. It can drive PI's like the Hammerhead, Gary's PI, Goldscan4 etc.
There are 3 outputs to drive analogue switches or JFET's, most PI's only use 2. The delay between each output and the sample width are adjustable from 0.5uS to 512uS and are displayed simultaneously on a 16 character * 2 line screen. The screen will have another page to show a digital readout and bar graph of the final stage signal strength.
Two pots and a pushbutton serve to navigate around the adjustments and displays. Turning the "mode" pot will cause stepping between various screen pages and variables. The "adjust" pot causes the variable to be changed with the "accept" button storing the new value. Adjustments will be live, so the user has instant feedback. There will be provision for storing (retained with power off) 16 sets of all variables into EEPROM.
Feedback and suggestions for additions are very welcome and the sooner the better as I am in the process of laying out the board.
To complicate things, I have finally bitten the bullet and started to learn to use "Eagle" light PCB program after using a DOS version of PROTEL since 1990.
bugwhiskers
bugwhiskers
) the schematic has been changed to incorporate a 3 axis type. The X,Y axis will be used to detect sweep speed/or lack thereof and the "Z" (up down) axis may be used to instigate ground balance.
