Advanced PI coils
    Here are the Tandem coils, same phase and opposing phase
    Note the distance of the coils is not the same for the 2 pictures
    Thanks Tinkerer,
    I'm thinking of of another coil software upgrade to handle such coils too. Unfortunately, the target response is highly dependent on its orientation and the current software isn't capable to rotate it in it's maximum response orientation. Its currently a fixed orientated target position sweep.
    I'll look and see, whether I can make a quick & dirty upgrade. Although, I could calculate & analyse the two-box coils too.
    But one trivial coil is simple to do:
    The dual-field PI coil
    Cheers,
      Thanks Tinkerer,
      Cheers,
      Thanks Aziz,
      The dual field PI coil will be interesting to see.
      Intuitively, the Tandem coil would have to be 2x10" to attain the same depth. However, the depth is not everything. One of the problems with FE discrimination, is the very thin, rusty fragments of steel sheet. In the flat orientation, often the X response is less than the R response and then the fragment is not recognized as FE.
      The response of these fragments is highly susceptible to orientation. When presented vertical to the coil, such that the field lines are parallel to the surface of the target, the FE recognition is very easy.
      Having a detection field with a field line orientation that has a different angle, at a known distance from the coil, would help discrimination. It would also help with coins and nails, in short, any type of target that is highly susceptible to orientation.
        Some coil arrangements that have been discussed are described as having the ability to GB. Surely the only thing that can happen is that the amplitude of the ground signal is reduced from that of a mono coil, but that electronic GB will still be necessary. The only situation where a good cancellation takes place is when the coil is perfectly horizontal over a perfectly flat and uniform ferrite mineralised area. As soon as the coil is tilted either way the GB is no more as the amplitudes are no longer equal. Also, most operators swing in an arc to some degree. The GB must be a system that works on the t^-1 decay and be independant of amplitude. Since IMHO you have to do this, you might just as well stick with a mono coil or a coplanar concentric TX plus separate RX. The humble mono can be improved as we have seen by bifilar winding, differential preamp etc, and maybe double shielding. I have been making tests on a double shielded 12in mono and I can sample at 6.5uS with a non differential LME49990 preamp with input diodes. The double shielding, I hope, gives more like a 2nd order filter to rf frequencies. Certainly it is much less noisy and I can pick up more stations if I use it as a radio antenna. A bifilar mono with dual shielding should be even better. Maybe a 2.5 order filter .
        One interesting thing I noted when I was doing tests in Australia, was that for mono coils sitting on the ground surface the signal level at the output of the integrator (no GB) was the same for any coil diameter. This makes sense when you think about it. Also, the level was nowhere near saturating the preamplifier as some have thought in the past. This was on one of the worst ironstone areas in Victoria.
        Eric.
        My idea of using the Tandem coil configuration, is to measure the gradient only between the 2 coils. Unfortunately, this brings up the problem of sensitivity to any deviation from the parallel plane of the ground. However, there are circumstances where this is possible, for example with a underwater towed array or a wheel mounted array on a salt lake etc.
        Just ideas for now, not tried yet, but would appreciate any feedback.
        • The Dual Field Mono PI Coil vs. Mono Coil
          This is the performance relation of the dual field mono PI coil vs. mono coil. Both coil parts (outer and inner) have the same loop turns count but the total same inductance as the 10 inch mono coil (our reference coil). The inner coil has the half of the outer diameter TX coil. BTW, TX=RX (=300 µH), it's a mono PI coil.
          It is definitely a pin-pointing coil.
          Coil Comparison (Calculated Response Ratio to Reference Coil)
          © 2012 by Aziz Ögüt. All Rights Reserved. 29-Dec-2012
          Reference Coil: 300 µH Round Mono Loop Coil
          10" Dual Field Mono PI Coil (0.5)
          Target Depth [inch] Target Depth [cm] Relation to Reference
          1 2,5 2,421
          2 5,1 2,778
          3 7,6 2,046
          4 10,2 1,622
          5 12,7 1,400
          6 15,2 1,273
          7 17,8 1,195
          8 20,3 1,144
          9 22,9 1,109
          10 25,4 1,084
          11 27,9 1,065
          12 30,5 1,051
          13 33,0 1,040
          14 35,6 1,032
          15 38,1 1,025
          16 40,6 1,019
          17 43,2 1,014
          18 45,7 1,010
          19 48,3 1,007
          20 50,8 1,004
          21 53,3 1,002
          22 55,9 1,000
          23 58,4 0,998
          24 61,0 0,996
          25 63,5 0,995
          26 66,0 0,994
          27 68,6 0,992
          28 71,1 0,991
          29 73,7 0,991
          30 76,2 0,990
          Cheers,
          • Originally posted by Midas View Post
            Hi Eric,
            Thanks for all your very informative posts of late. What exactly do you mean by double shielding ? And what sort of pre-amp gain were you running when you say you were 'nowhere near' saturation? How much do you think you could run before it did become a problem? I seem to remember reading on here somewhere that more than 50 could become a problem in some ground.
            Midas
            Hi Midas,
            I've drawn a X section showing the shielding. As the shields are concentric with the coil x section, there is only minimal eddy current generated in the shield, unlike if you put the tape, or coating, flat on the coil shell with the result that flux links with it. This is the most effective way to shield a coil from the emi point of view, but not cost effective for large scale production. Both shields, in the dual shield coil, are taken to the coax braid, as is the ground end of the coil. For the bifilar centre tapped coil there would be a different arrangement which I will look at in due course. The shield needs a small gap in it so that it doesn't form a shorted ring, otherwise you will get serious eddy currents. I once damped a coil by putting the damping resistor across the shield gap instead of the winding. Seemed to work OK.
            Depending on the current you want to pulse, the wire I have used may be a bit too thin, but of course, this method of shielding is for any coil. 1190 copper fabric tape is hard to get now, and lead is even harder as it is classed as a hazardous material. I still have some for my own experiments but there are no doubt materials that are as good. Beware nickel tape though, as being a magnetic material, you do get a small, but constant decay from it.
            The preamp gain I used was x500. You would run into saturation on the later dc amplification stages long before the preamp caved in.
            Eric.
Name:	Coil X section1.jpg
              Eric.
              [ATTACH]22524[/ATTACH]
              some kind of coaxial cable?
              Eric, what material do you think that will be the best for this "type" of shielding, regardless the cost or availability?
              • CAT5e UTP cable. Just don't forget to leave a slit in a shielding at some place to avoid short circuiting your coil.
                There is no question about replacing the rig GB with a coil, but complementing it and improving the overall situation. As I learned here about the maghemite fields in OZ, they are pretty layered due to the bush fires etc. but otherwise the offending ground is quite homogeneous, and some angle against the ground surface will not spoil the coil's GB ability by much. My situation is a combination of red clay (homogeneous) and shallow sea (mostly homogeneous). A bit of slant will surely spoil GB a bit, but it will still improve things. I already made a wet salt ground balancing add-on project for my VLF so I'm not going there unprepared.
                Right now I'm covered in paint and putty, but I'm also FINALLY equipped with a real 2 channel 20 MHz CRO, so my lab is now up to something.
                • Originally posted by Bill512 View Post
                  It all comes down to conductivity. The woven copper fabric 25mm wide tape I favour has a resistance of 1 ohm per 300mm. It has an adhesive backing which keeps it in place and it is solderable with care and not too much heat. Another candidate which is often available on ebay is 3M Scotch 24 tinned copper mesh tape. This has a resistance of 5 ohms per 300mm, but has no adhesive backing. Plain adhesive backed 0.05mm copper tape is no good as the eddy current signal generated in it persists for about 30uS even with a gap. It's resistance per 300mm is <0.1 ohms. Basically, look for a solderable adhesive backed tape that has a dc resistance of between 1 and 5 ohms per 300mm.
                  A search of web sites that deal in EMC products may come up with some useful material which I don't know about. I have enough NOS to keep me going for a couple of years on development projects, so I haven't been looking.
                  Eric.
                  • Coil Software Upgrade Gonna be Complex
                    Hi all,
                    1. pity: no quick & dirty solution possible at the moment. I have to "arrange and adapt"(c)(r)(tm)*LOL* some code parts and this requires more coding & testing time.
                    2. pity: I can start the coding in the second week of Jan. 2013 or later.
                    3. pity: tomorrow till second week of Jan. 2013: won't have much time to contribute to the interesting thread.
                    But keep on posting all the good ideas, so no one in the well-known company can patent it anymore.
                    Cheers and a Happy New Year to you all.
                      Some places in Oz may be like that, but in the Victorian goldfields it is a little different. There is one area where the strata are at a steep angle and in one sweep of the coil you can cross several thin bands of highly viscous material interspersed with bands of low viscosity. Now that's ground noise. Ground noise gets worse on a hot sunny day as rocks, gravel etc on the surface heat up and this alters the decay law slightly. The underlying material which is shaded doesn't change so you have a spread in the exponent which makes GB less accurate. At night or after rain the temperature gradients even out and the ground becomes quieter. Some rocks and areas have a remanent magnetisation (thought to be caused by lightning strikes). Imagine sweeping the coil over a bunch of small ferrite magnets. That's ground noise. Some areas have layers of hard ironstone on top of a red clay. Again the decays are slightly different and in areas of old diggings both can be exposed together at the surface. Bush fires do make a difference. Intense local heating converts magnetite to maghemite which enhances the viscosity. Around trees which are burnt you often get a stronger ground signal which is so localised it sounds like a large deep nugget if the GB is not adjusted correctly, or for auto GB, not keeping up with the changes. Prospectors sometimes dig these signals only to find they fade away as the hole gets bigger and all they have are bits of barbequed tree root.
                      I have experienced the above at first hand and measured samples of the ironstone on a Bartington MS2B susceptibility meter, and my own viscosity meter. There is nothing like it. The demining literature quotes a lot of tests done in the Hawaiian volcanic islands, Mozambique, Cambodia and other places and they give figures of susceptibilities and viscosity (frequency dependent susceptibility), but it's no exaggeration to say that in the Victorian goldfields you can multiply the figures by ten. I will look out some results and post them in due course. This is important because it shows what a detector coil can be up against in the worst conditions.
                      Western Australia is reputed to have more uniform ground, but I have never taked a detector there, or measured any ground samples.
                      Eric.
                        Hi Mida
                        Eric.
                        Hi Eric,
                        Just for interest sake, the coil i have been mentioning with the tubular coil bundle didn't need any shielding at all to work directly under a power line, i think it worked because the "current" flowed around the coil bundle 3-4 times before exiting providing it's protection from EMI, i never tested this coil on noisy ground as i live on the beach front. This coil was a mongrel to wind as i had to hot melt glue it to a form and it would not work for a large coil as there would not be enought "turns" of wire to cover the form.....anyways as i said, for interest sake
                        Ron
                        • Originally posted by authere View Post
                          Hi Eric,
                          Ron
                          Do you still have this coil ?
                          If so maybe you could post up some pictures, so people here can see what your talking about.
                            Hi Midas,
                            Eric.
                            OK cheers Eric, I'll definitely crank my preamp gain up a bit then. The coil I'm using at the moment is 6.5" made from .5mm solid core Teflon wire wrap, its shielded with just one layer copper mesh very similar to scotch 24. I didn't use a spacer mainly because I didn't have any Teflon spiral wrap lying around but it doesn't seem to have added much extra capacitance anyway (still a sub 6us coil). I was certainly happy with the noise reduction I got when I added it so I'll see if can source some spiral wrap (and stranded Teflon wire if I can get it..) and add another layer as you suggest. BTW I don't think I'd be recommending the Kynar, it seems to have one of the worst DC I've seen for any insulation.
                            Midas
                              Midas
                              Hi Midas,
                              That is interesting about the Kynar having a bad DC. I just assumed that having a fancy name it must be better than PVC. Goes to show - don't just assume anything; check! All my coils now are wound with Teflon wire as I bought several large reels of different gauges from a company that closed down. I also have some stranded Litz of the same equivalent gauge as 0.25 solid. I wound two otherwise equal coils and saw no discernable difference in performance. For higher current pulses I use stranded Teflon insulated high temperature wire. This paper, and others in the references, could explain why Litz doesn't give any advantage in PI detector coils.
                              Page Not Found 404 Error Sorry, the page you are looking for could not be found. The information you are looking for is likely still here, just…
                              What is the resonant (ringing) frequency of your coil + cable.
                                Hi Midas,
                                I pinged it at around 1.4mhz before I added the shield. I have no real cable on it yet the coil just goes straight into the TX board.
