My DD27 is not working very vell so i make 25cm concentric, .
idx concentric
hiOriginally posted by akasyto View PostMy DD27 is not working very vell so i make 25cm concentric, .
are you make like TGSL coil with Don pdf ?
is it work ?
i make CC coil for IDX but dose not work and really need help any one teach all better.
Edit :
i make DD and can not discrimination but can detect in air 2.5cm coin near 30 cm . but again please any one teach me to make CC coil .
I make it like that:
30T TX 10T Fb 0.65mm wire 1uF+22nF capacitor
310T RX 0.19mm wire 33nFAttached Files
dear golfnut please guide me too . i have this problem yet . and if you can help me to make another CC coil .Originally posted by golfnut View Postdiscrimination was bad,i think machine is ok.Detecting 1 euro coin on 32cm in air with this concentric.
Does the concentric discriminate and the DD not discriminate?
The initial phasing is off, your goal is to reject ferrite.
Adjust the physical overlap to tweak phasing of Tx drive wrt to Rx preamp out. Check with ferrite. When you can tune out ferrite with Geb, the Iron can also be rejected with the disc
Tweaking the Rx coil cap by a few nF can also tweak phasing of your coils are potted.
This is the oscilogram of my 8" concentric coil.Attached Files
at left top corner of the pic I took a diagram from 5900 di pro schematic. it is NOT IMAGING real state of coil.Originally posted by akasyto View PostI make it like that:
real coil schematic is ANOTHER, that I did draw in the center of the coil, center of the pic.
remember this moment.
