I've been making DD coils for long time, maybe made 200 so far, maybe more, never really payed much attention on numbers.
Each time i made my coil the same way. As i explained and showed in PDF file here on forum.
It is obscure and primitive method... but efficient enough.
Usually inductances are known, so only thing left in such cases is to put both "D" coils in enclosure and balance them.
Balancing... usually most delicate part!
I noticed that sometimes it goes easy and sometimes not.
Modern coil designs seems tending to reduce coil weight more and more, reduce coil mass too and overlapping area is narrowed and straightened more at modern coils.
So now we have quite a number of modern DD coils which are light weight, interesting design and with ultra narrow overlapping area.
It is much harder to balance coil with narrow and straight overlapping area (figure B on posted sketch below), i realized that recently.
It is much easier to balance coil with wider and "belly" overlapping area (figure A on posted sketch below).
So far i had success only with case "A" (figure A).
But recently i got salvaged enclosure from XP coil, 36x30cm and i tried to make coil to fit that enclosure, for another type of detector.
Once i put coils in enclosure and tried to balance them; i realized it would be tough!
After ten minutes somehow i got some balance, but it was damn critical!
My coils are close with dimensions and i don't have enough space inside enclosure to move them more to balance them better.
So i was wandering; how it was done by manufacturer?
How they calculate coils so later to have sure comfort that coils will be easy balanced in such narrow and straight space where overlapping area is?
How to take overlapping area, shape and dimensions into account to be later sure that you will balance coils easily?
If you look some of the commercial coils and their design; overlapping area is so narrow and precise... that from this perspective i can't think on method how to calculate the coils to fit perfectly in such enclosure!?
What is the secret?
What is the secret?
