This design tried it in an ellipse and it gives good aerial results. Now I don't have a housing for the new one. I'll have to come up with something.
Ground balance compensation coil
https://www.geotech1.com/forums/foru...me=#post203837
This method looks good. Has anyone made a similar device?
Ground decay depends on the ground. Ferrite-like mineralization is almost instantaneous and vanishes in 1-2 us. Viscous mineralization takes longer and depends on the composite decay coefficient and the peak strength. Yes, it can extend beyond 100us.
Thank you, Carl. So the mineralization remains in the spike formed by the reverse electromagnetic field.Originally posted by Carl-NC View PostGround decay depends on the ground. Ferrite-like mineralization is almost instantaneous and vanishes in 1-2 us. Viscous mineralization takes longer and depends on the composite decay coefficient and the peak strength. Yes, it can extend beyond 100us.Attached Files
Hello, esteemed group. After twenty years I intend to return to designing MD, but first knowledge and science. A question about the BUCK balancing coil in the BM950 type coaxial probe. What if the BUCK coil is inside the receiving coil? What advantages and what problems will arise?
