Ground balance compensation coil
  • #31
    This design tried it in an ellipse and it gives good aerial results. Now I don't have a housing for the new one. I'll have to come up with something.
    • #32
      Hi Ivoint.
      Are you believe strange coil's configurations will solve some discriminations problems in metal detecting?
      • #33
        • #34
          https://www.geotech1.com/forums/foru...me=#post203837
          This method looks good. Has anyone made a similar device?
          • #35
            Google _ super dd coil
            • #36
              Hello guys. How long does it take for a signal from the soil to decay after a Tx current duration of 60 us. Coil diameter, 30 centimeters, inductance, 350 uH, current, 1A.
              From - To?
              • #37
                Pito, thank you.
                • #38
                  Hello, Pito. Is it true that the decay time of the ground response can be in the range of 90 to 200 us.
                  • #39
                    Ground decay depends on the ground. Ferrite-like mineralization is almost instantaneous and vanishes in 1-2 us. Viscous mineralization takes longer and depends on the composite decay coefficient and the peak strength. Yes, it can extend beyond 100us.
                    • #40
                      Thank you, Carl. So the mineralization remains in the spike formed by the reverse electromagnetic field.
                      • #41
                        Correct.
                        • #42
                          Hello boys.
                          I've mentioned it before - that a high peak doesn't help with mineralization.
                          It's another matter who wants to dig how much.
