TANDEM COIL
Hi Aziz,
thanks for offering your help.
Intuitively the TANDEM COIL has some specific advantages. Vertical targets give a weak response with traditional coils. With the TANDEM COIL, there is a large field vector that would hit a vertical target on it's side and should therefore generate a stronger response.
The TANDEM COIL also allows for an interesting variation of RX coil combination. One could use a single rectangular (or center tapped) coil across the 2 TX coils, where the physical structure would be reinforced as well as the RX would be balanced.
Another variation would be 2 RX coils, one in the center of each TX coil.
Another variation would be 3 RX coils, one at the center of each TX coil and one across the center.
There are many other variations possible, including anti-interference variations.
I did build a TANDEM COIL some years ago and was very satisfied with the performance.
Would you be so kind, to run a TANDEM COIL model in your software?
I think the basic coil disposition should be with the 2 coils aiding, but the 2 coils opposing also has some (different) merit.
All the best
Tinkerer
Originally posted by Aziz
All the best
Tinkerer
Domains are not joining. There is something happening above, a minimum is pushed somewhat, but I think more slant will not be practical, at least for my purpose. It seem that more slant will not do much.
