Single layer Spiral coil
  • #61
    Tinkerer, can you provide pohotos of concetric loops?
    1. reverse current in inner half scale of outer dia of 25cm and inner about 12,5cm
    2. same values but current in same direction in both coils.
    Thanks alot for these nice pictures.
    • #62
      I think you mean the "classical concentric IB" configuration.
      This would be about 20 turns outer TX and 5 turns Bucking coil inner.
      It is Aziz, not me doing these fantastic visualizations, made with his own software.
      Tinkerer
      • #63
        Yesss! That's it. A blue dot in between (to place PCB etc.)
        Hi Davor,
        if you increase the distance of the coils, the "blue dot" region grows. Below is the coil diameter distance of the coils.
        • #64
          other cross-section
          • #65
            True, but as they are separated further, they become more independent, and less mutually supporting. I aim for a system that comprises 4 coils in a kind of lucky clover design, and with the least possible spacing between them and with no overlapping. Hence the distance specified. Two and two coils in criss-cross will be arranged in antiseries and hooked respectively to Rx and Tx providing a perfect double balanced IB system. And electronics in a center of it all. Works perfectly in my head.
            • #66
              Here is the classic concentric co-planar IB coil.
              Cheers,
              • #67
                Aziz: what program do you use? I would be very glad to get used it in my engineeering studies. I would need still the inner coil reversed photo to think which configuration is better.
                • #68
                  This software program isn't available. Nowhere in the universe.
                  I have written this software.
                  PS: No, I do not sell it either.
                  • #69
                    Great stuff - with this visual calculators it should be
                    possible finding the strongest field concentrations!
                    because we wanna reach most distant metal by induction this info may helpful:
                    http://en.wikipedia.org/wiki/Wireles...etic_induction
                    also called: inductive power transfer (short: IPT)
                    What I don't understand:
                    Why the bucking coil B should "push" the field of coil A and
                    doesn't weaken or disturb it.
                    Vice versa seen the field of coil A could also pushes the
                    bucking coils B field so that one extends.
                    Electromagnetically seen the at say 10kHz pulsing and if both
                    coils are connected to the same TX source and pushing each
                    others EM field alternates all the time.
                    So I think the bucking coil only can work if it
                    has a steady magnetical field / current flow.
                    Or does the bucking has just half of the windings
                    compared with the working one?
                    Otherwise it results same as the electronical noise canceling
                    system used in helicopters -negative and positive sound
                    vibration amplitutes are deleting each others.
                    And not only the bucking coil "pushes" the field but also
                    the main working coil pushes the bucking coils EM field
                    into upper direction - but this only applies to the
                    short distance inbetween those coils; if the bucking
                    coils negative magnetical field reaches through the
                    working coil and beyond it, it will weaken the at that time
                    positive magnetical field which the working coil wants
                    to spread at the same time into this direction.
                    And what a role could ferrite play in this game?
                    btw. afaik an electromagnet with soft-iron-core reaches more
                    attraction than an "air-coil". Transformers too use such stuff
                    to reach higher efficiency. But thats 50-60 Hz and not 10 kHz
                    so I don't know.
                    Couldn't work a slighty like sat.-dish shaped spiral-coil
                    pointing down as focus to keep the EM-field directional?
                    • #70
                      hello aziz
                      i like your coil calculations since first time i see them
                      can you show visualisation for our homemade coils?
                      would calculate it by my own but without any help and no program i cant show result.
                      why do you sit on your knowledge and dont share, many thinks would be easier in live if we had the right tools. make a comercial product from it.
                      • #71
                        hello aziz
                        Hallo Bernte,
                        specify your coil (exactly and not wishy-washy! ) and you will get the visualisation of it (for free). It must be published in the public domain however. Deal?
                        Nobody could operate the software without the extensive knowledge of the software internals and electro-magnetics (EM). To write a manual for the software would cost me a long time and big effort (for nothing).
                        On the other hand, the coil software has some potential for finding novel coil inventions (as happened on the 1. April 2012 ). I don't want to give it to the f$kn evil patent trolls. These inventions should be available to everyone instead. And I can guarantee the publication of it. So every coil design, which is suggested for analysis will be published in the public domain to avoid it's possible patenting.
                        The coil analysis causes a lot of work and I do it for free of course. I think this is a fair deal.
                        Cheers,
                        I hate patent trolls!!!
                        • #72
                          hello aziz
                          i can understand you,
                          the offer you made is a word for me
                          i go to measure my coils and give you the data for calculating, many thanks.
                          • #73
                            Hello Aziz.
                            I have worked on open source software for many years. Putting a license on your software would free you from patent trolls. You could even publish your source code and put your software on the internet with the correct license. For example the GPL license will require people who improve your code to publish it. This way you will always benefit. Just my 2 cents...
                            Joop
                            • #74
                              Originally posted by joop View Post
                              Hello Aziz.
                              Joop
                              Hi Joop,
                              I do not want the patent trolls to use my software.
                              • #75
                                Is there any partcular reason why dont you provide closed source version of your program for free? This way you get to keep your code and people may use your work as it seems to be so brilliant. Could you provide a bit more practical reason why you prefer to keep such program only for you?
                                I my self support open source programming but that said, they usually are gui based programs for something and not pshusics calculation software. But since opensource rivals closed source programming and it benefits from user base growing and adding features fast where in counter closed source tend to keep things going slowly.
                                But that said, I dont see any reason why would you not take credit of building such outstanding magnetic simulation software as closed source?
