Epe pic magnetometer
  • SimonS
    No, there is nothing wrong with program in PIC. For some reason cannot read EEPROMs. If you have osciloscope you should check SCH and SDA line. If not, just look for some errors on boards. Do you have jumper under EEPROMs?
  • lazzy
    Dear friends
    some issues re the EPE mag logger:
    I recently built a new unit (the original was broken...) and I have the following problems:
    * the pic does not recognize either of the installed eeprom chips (message "0 eeprom chips"), even when only one chip is installed
    * when the eepprom erasing function is invoked ('Null' + 'On' switches), the software shows that chip 1 and 2 are being 'cleared' but then continues with 'chip 3' (?!) and so on (probably, because no eepprom's were found)
    * although the 'Record' function seems to work, no data are written to either of the eeproms
    * no data are transferred to PC upon activation of the relevant function
    The circuitry as well as all connections to switches seem to be ok; 5V is established where necessary, while all components were checked and seem not to be faulty.
    The PIC (16F877-20) has been initially programmed with both Microchip's Pickit3 and Velleman's K8076 programmers; it was then re-programmed with the same devices, but without improvement with respect to the above behaviour.
    One other thing to be noticed is that after some programming sessions, the PIC program was not working at all, showing only the message 'EPE Magnetometer, 0 eeprom chips' but no other function whatsoever; while, after some other programming sessions it functioned like the descriptions in the beggining of the post.
    Finally, I tested the same PIC on two similar PCB's, and the overall behaviour is exactly the same on both boards (some times a faulty function, some other times no function at all).
    Is this a problem of the PIC, of the programming, or of the board circuitry?
    Any help would be much appreciated as well as any tips regarding the testing of the circuit.
    TXs
    lazzy
  • SimonS
    You can look at site http://www.speakesensors.com
    There is contact e-mail.
  • rocco_k
    where to buy fgm-3.thanks
  • WM6
    Originally posted by SimonS View Post
    Maybe aluminium tube is like "shild". Try to remove aluminium tube and try only to use only iron peace how it work.
    If this happen from vicinity it is ok, because FGM-3 sensor is not absolutely passive sensor like compass, it is in connection with target movement an active sensor, and can act as weak metal detector from vicinity too.
  • ivconic
    Some checks and experiments with metglas tape.
    Also checked "core" taken out from ordinary AAA battery.
    Have heard somewhere that those battery "cores" are made from high permeability materials and also can be used in sensor coil setup... well, it seems this one i checked can't!
    Anyway... it is interesting to see that coil with 12mH inductance can rise it up to 75mH with high permeability core inserted
  • ivconic
    No, is not the reason.
    I also tested with several other items too.
    Generally; small iron objects are detected only at lower sensor area while larger (and massive) iron objects are detected only at upper sensor area.
    This "phenomena" is further emphasized because of the current electronics i hooked up on sensor, but generally this is one of the features of FGM-3 sensor, and i suspect that it has something to do with it's geometry inside.
    There is certain "signal overlap" area, somewhere in the middle of sensor body and that's so obvious when experimenting with standalone sensor hooked up on oscilloscope.
    I noticed that several years ago, when met these sensors for the first time.
    Now, with simple electronics and few tricks, i am trying to use this FGM-3's "drawback" and turn it to certain benefit.
  • SimonS
  • ivconic
    Very interesting!
    How it possible to detect aluminium anyway?
    I guess is not possible.
    At the moment i was delighted... but few moments later i realized that there was iron bar inside aluminum tube! Daaaaamnnnnn!
    But another thing here is interesting; "massive" iron pliers are detected only by upper sensor area and not also by lower sensor area, while;
    not so "massive" iron bar inside aluminum tube is detected only by lower sensor area and not at all by upper sensor area!?
    How about that
  • SimonS
    Very interesting!
  • ivconic
    Funny thing!?
    Iron pliers are nice detected only at upper FGM-3 area while not detected at all at lower sensor area.
    And vice versa; aluminum tube is detected only at lower sensor area and not at all at upper sensor area!?
    How about that?
    I just finished this and it is in preliminary testing. Ultra simple circuitry with ultra simple idea... and yet gives interesting results!
    I will have to change some things more on it further.
    Until than
  • ivconic
  • IC-77
    Sorry, Mr. Simons, there was some confusion or replace personal forum by some članoa, but I think it's still just a mistake and nothing else. Regards,
  • SimonS
    Originally posted by IC-77 View Post
    Sorry Mikipn, you're Simons, this is another that reads Slovenian Serbian press, and her image printed circuit boards, which gives only someone citizens in Slovenia.
    I'm sorry, but I don't understand what you write...
    Also what I do wrong, that you write so bad about me? Also me use always same name for all forums and only one account. I have nothing to hide...
  • mrkhrdr
    zenit,
    I doubt that a PI detector would detect a gold nugget at that depth. A larger object (good luck!) might be found at that depth, however. You need to use a large coil to detect at depth, but a large coil is less sensitive than a small coil, so a deep object needs to be larger than you would expect to be detected only a few inches below the surface. To find small objects close to the surface, it's best to use a small coil, because they are more sensitive than the larger coils would be.
